Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-12-2004, 12:10 PM
jfn jfn is offline
jfn is starting off with a positive reputation.
93 2.3L Water Pump Replacement
I have followed my Haynes manual to the "T". Following steps are complete.
1. unhook the neg battery cable
2. drain the radiator and remove it to make the job easier
3. remove the serpentine belt.
4. remove fan clutch and waterpump pulley
I am stuck on
5. remove out timing belt cover.
All retaining clips are loose but it seems like i have to take off crankshaft pulley/harmonic balancer in order to get it off. Do I need to follow the same steps listed in the "2.3L timing belt replacment doc" in order to get my outer timing belt cover off?
-remove all 8 spark plugs
-turn crankshaft pulley until piston #1 is at TDC
-remove pully
Any help would be greatly appreciated.
  #2 (permalink)
Old 05-12-2004, 04:14 PM
jfn jfn is offline
^bump ^bump
  #3 (permalink)
Old 05-12-2004, 05:39 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
did you take the bolt off the timing cover? there should be 8 clips and one bolt. and you dont need to take the balancer off to get the cover off.
__________________
1991 Ranger EFI 4 banger 2wd w/ M5OD Transmission
  #4 (permalink)
Old 05-12-2004, 06:01 PM
jfn jfn is offline
Yup, I have taken off the timing cover bolt and all 8 clips are loose. The problem w/ removing the cover is that there is about 1'' of it under the crankshaft pulley.
From your post below, it seems like Dayne was having the same problem w/ the outer timing belt cover. You recommened taking off the pulley and balancer.
http://www.ford-trucks.com/forums/showthread.php?t=222669&highlight=timing+belt+
Let me know.
  #5 (permalink)
Old 05-13-2004, 04:34 PM
jfn jfn is offline
^bump^bump
  #6 (permalink)
Old 05-13-2004, 04:48 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
I look at my Ford manual after work if no one gets back to you.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #7 (permalink)
Old 05-13-2004, 04:50 PM
jfn jfn is offline
Ken,
Appreciate the help. Look forward to hearing from you.
  #8 (permalink)
Old 05-13-2004, 07:29 PM
Ken00's Avatar
From my 1989 manual...
Drain coolant.
Remove two fan shroud bolts.
Remove four bolts retaining fan to water pump and remove shroud and fan.
Loosen AC compressor adjuster pulley and remove drive belt.
Loosen power steering bolts and remove alternator and power steering belts.
Remove water pump pulley. Vent tube to canister.
Remove heater hose to water pump.
Remove timing belt outer cover bolt. release interlocking tabs and remove cover.
Remove lower radiator hose from pump.
Remove water pump retaining bolts and remove pump.
__________________
Ken
  #9 (permalink)
Old 07-03-2007, 08:51 PM
jas30459 jas30459 is offline
jas30459 is starting off with a positive reputation.
I just moved the cover out of the way far enough to get to the water pump bolts and it worked just fine. I did not take the cover all the way off.
  #10 (permalink)
Old 07-05-2007, 01:11 AM
jfn jfn is offline
Yes, all I had to do was remove the outer timing belt cover. This allowed me to access all the water pump's bolts. HOWEVER, since I had over 150k on the orginal pump, the hoses basically melted onto the input / output of the pump and required me to remove the alternator and alternator bracket as the hoses snake thru the bracket.
Took a bit longer to free all these bolts that have never been taken off for over 10+ years! Thanks for the help and my truck is back to normal.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
