Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 05-12-2004, 08:58 AM
MichiganHunter MichiganHunter is offline
Garage is empty, add now
MichiganHunter is starting off with a positive reputation.
Question Help on K&N!
I have a 2002 F250 SC shortbed 4x4 that I recently put a 6" BDS Lift and a set of 315's on the truck. I have a 5.4 with 3.73's right now and I am going to upgrade the gears as soon as I can get some answers on gears, I have no idea about how geras are going to change the truck's performance, Just alot of here say.. I have been told that 4.56's will get me some of my gas mileage back because the truck is not working so hard and others are saying it is going to make it worse than it already is, I get about 9-10 after the kit was installed and tires were changed. I hope someone can she d little bit of input on this one for me. And I also have another question about the K&N Fuel Injection Performance Kits, Does anyone ou there have one on there truck, and if so Can they really feel the difference in power? I would hate to fork out the money on this cause they are a little expensive unless they work, Thanks again and i hope someone out there can help me out.
  #2 (permalink)
Old 05-16-2004, 11:41 AM
RonnieB RonnieB is offline
RonnieB is starting off with a positive reputation.
I am assuming you have the 265s on now? If so, you added about 3" in diameter to your tires, so translated, that's about 9% torque loss. A set of 4.10s will get you roughly back to factory. 4.56s will allow you to launch, but will cause you higher highway RPMs, which lead you to lower fuel economy, and may cause you to tow at slower speeds since you will now be out of your power band at the same highway speeds. If you're looking for better launches, but want to save some fuel, I think a good compromise would be a set of 4.30's.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
