Distributor Problem...
Old 05-11-2004, 04:36 PM
javi2001's Avatar
javi2001
javi2001 is offline
Hi guys, I don't know if this is the best group for my question but here it is...
I own and F150 1986, carby, recently I notice low fuel economy and after some cheking I found the centrifugal advance springs inside my distributor were broken. I got both from an used one but of course it needs to be calibrate for proper advance and my questions are:
1° someone knows how many degress should advance timing as RPM is increased??? (Not vacum advance, centrifugal advance)
2° A friend recomend me upgrade to MSD distributor it worths???
Thanks for any help...
Old 05-11-2004, 10:52 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I wouldn't recommend the MSD dizzy on a basically stock application. It would be a waste of money.
I am thinking that by 3000 rpm you should get between 15 and 20 degrees of mechanical advance.
So if you have 10 deg initial, at 3000 rpm you should have around 25 to 30 deg total.
Old 05-14-2004, 10:09 AM
javi2001's Avatar
javi2001
javi2001 is offline
Ok. I'll try this range of mechanical advance.
Any info on how to clibrate Vacum advanced? the only info that I found is it should start to advance at around 5" to 7" Hg vacum, but not How much should advance for about 10" or 15"....
Thanks
austral
05-29-2016 08:36 AM
thundersnow70
08-14-2014 08:17 AM
Wyowanderer
19
03-02-2014 12:33 AM
javi2001
15
07-03-2003 05:03 PM
goodyear
12-01-2002 09:12 AM
Quick Reply: Distributor Problem...
