Transfer case is gear drive or (ugh)chain drive?
If the (ugh) in your post is referring to the weakness of chain drive transfer cases, take a look at this.
http://www.newventuregear.com/tcases.html
You've either got the NV231 (manual shift) or the NV273 (electronic shift). I think with a max torque rating of 7980ft.lbs., you'll be ok no matter what you throw at it!
I bought this truck because I had a 95 dodge dakota and had to have the transfer case rebuilt at 80,000 miles. (And I never used the truck hard). It was very expensive. So please continue my education or tell me something I want to hear like how much better this transfer case is than the little dakota's. So does this one company supply the transfer cases for the big 3? For the record I have a F-250 supercab, 8' bed, V-10, and 3.77 limited slip rear end and 6 speed manual transmission, and manual get-out and lock 'em in hubs.
Thank-you both for replying.... And take pity on the uneducated.
Why is the electronic shift rated so much higher than the manual? Is it really that much tougher?
Transfer case discussion
First Thank you to all who replied. Good information.
Going off on a tangent. the same guy who (verbally)told me I had chain drive and caused me to come to FTE for confirmation has subsequently told me new venture makes a gear driven transfer case model 205 that rock climbers use. He thought it might be possible to install it. I assured him that would only become a possibility if mine went out and was not under warranty. Anyone care to comment on this ?
Still waiting for someone to tell me how many manufacturers use new venture transfer cases.
Can someone explain to me why the NV271 is rated (7890 ft/lbs. torque) for 18.5 times the torque my V10 (425 ft/lbs torque) puts out? Am I missing something here? Wouldn't that (7890 ft/lbs. torque) be equivalent to several thousand horsepower?
I looked around on the web, and the Dodge 2500 and up use the same transfer cases. These things are very strong. The chain should last just as well as a gear-driven, maybe even better, because the idler gear in the middle of a non-chain case takes a lot of strain and can fail just as easily. The key is lubrication.
The reason the torque rating is so high is that you have to take into consideration the transmission gear ratios. With a 6-speed, low is 5.79:1, so take peak torque from the V10 (425) and multiply it out, that's 2460.75 ft-lbs out the back of the tranny. Then, if you use 4x4 LOW, that's another 2.7:1 gear reduction, that's 6644 ft-lbs. If you have a diesel, putting out over 500 ft-lbs, you get pretty close to the max rating.
Check this out:
http://www.landscapemanagement.net/l...l.jsp?id=93085
GM uses the NV273 (electric shift) in their medium-sized trucks.
Um... if they use the same transfer case as our SuperDuties in a medium-duty truck, what do they use in their pickups?
npearman
1997-2006 Expedition & Navigator
31
02-16-2016 04:01 PM
tubby12729
11-12-2012 07:55 AM
