87 302 Can't set timing.
My 87 e150 van with a 302 lost power and died at 40mph. Put on new ignition module and it fired up but I had to move the distributor to get to the module so timing was off. I removed the spout connector, set timing at 10 btc then replaced spout connector, engine idles rough then won't re-start. Checked and found code for tps so I replaced it, still have to advance timing to 30 btc to start engine and after returning timing to 10 btc it idles rough, almost dies when throttle is pressed, and won't restart. Any ideas?
New module, new sensor in dist., new cap and rotor, Spark plugs look good. Set timing and it sounded good but when I touched the throttle it died and wouldn't re-start unless I advanced the timing to over 25 degrees. Could a timing chain with less than 3 degrees of play cause this much trouble?
You might try over in the 302 engine forum to see if you get more responses. Here's the link: https://www.ford-trucks.com/forums/f...splay.php?f=55
Good luck!
Good luck!
54321toz
34
05-09-2017 03:53 PM
PapaBearYuma
16
11-13-2016 08:18 PM
rshiver
1983 - 2012 Ranger & B-Series
12-12-2009 01:23 AM
Oregonbythesea
16
04-19-2008 02:19 AM
