95 PSD Running Rough
I have cruised through several pages of posts and have not been able to find similar conditions. My truck has been "stuttering" at an idle for the last couple of months but running ok. Last Friday it started running rough like it is missing on some cylinders. It has 130K and has run fine up to now but it needs something. Would this be a symptom of the dreaded CMP failure or what are the life expectancies of injectors. It has a fresh oil, fuel and air filter so thats not it. Anyone have any suggestions?
Yes, it is most likely the CMP Sensor. I'm sure you've seen these, but here they are anyway:
http://community.webshots.com/photo/...84042038YpzSoJ
http://community.webshots.com/photo/...84046575HPSSqb
Depending on the build date, the 95 can have a DLC(data link connector) under the dash below the left side of the glove box or under the hood if it is still EECIV style. If your PCM tag is F5TF-12A650-BTE or before (I think) the two piece connector should be under the hood, left side near the hinge.
OK Latest news. I changed the CMP and it has helped but the truck is still not running right. Has a "stutter" in its acceleration and vibration as it goes down the road. Almost like a tire out of balance but thats not it. Any other ideas and thanks again for the info on the CMP and where to purchase one. BTW You can get it from advance auto as well for $230. I prefered mine at $92.00
I've been having the same problem with my truck. I took it to Ford and there service tech told me that the problem was that the dual mass flywheel is wore out and that i need a new one. Of course u can't just replace the flywheel because usually when it goes it messes up your clutch. If it is your dmfw you have two choices 1. put a new dmfw in but they are really expensive or 2. install a afternmarket one with a single mass flywheel and a regular clutch. I'm going to install a single mass flywheel and clutch when i get the money and it seems that alot of people have went this route. LUK seems to be a favorite choice here on the form.
