identifying engine
Old 05-09-2004, 04:30 PM
superD2500's Avatar
superD2500
superD2500 is offline
identifying engine
A buddy of mine pulled an engine out of what appeared to be a seventies ford medium duty truck with a water tank on it. My buddy doesnt know much about fords, so he thought the engine he was pulling out was a 429. After he got it home I took a look at it and was able to tell that it was no 429. I am not sure what engine it is, but it is very large. the intake manifold is part of the head like an FE motor, and the block appears to be Y shaped. It has a 2 barrel carb on it, and the thermostat housing is on the front of the block. I have been told that this engine is probably a 401, because of the 2 barrell. I was wondering if anyone could help me identify this engine as a 401,477,534, or if it is just an FE truck motor. Thanks
Old 05-09-2004, 08:58 PM
ML1983's Avatar
ML1983
ML1983 is offline
It really depends on what it came out of. If it was an F-500 up to F-800 then the engine is probably a 330, 361, or 391. I think the 401/477/534 were only used in the C-series and conventional cabs beyond the F-800.
Old 08-12-2004, 02:05 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
It Is A Ft Motor A Heavy Duty Version Of A Fe Motor
Old 08-13-2004, 10:59 PM
f600nightmare's Avatar
f600nightmare
f600nightmare is offline
its an ft they had 359 361 391 etc
