Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-09-2004, 04:30 PM
superD2500 superD2500 is offline
Garage is empty, add now
superD2500 is starting off with a positive reputation.
identifying engine
A buddy of mine pulled an engine out of what appeared to be a seventies ford medium duty truck with a water tank on it. My buddy doesnt know much about fords, so he thought the engine he was pulling out was a 429. After he got it home I took a look at it and was able to tell that it was no 429. I am not sure what engine it is, but it is very large. the intake manifold is part of the head like an FE motor, and the block appears to be Y shaped. It has a 2 barrel carb on it, and the thermostat housing is on the front of the block. I have been told that this engine is probably a 401, because of the 2 barrell. I was wondering if anyone could help me identify this engine as a 401,477,534, or if it is just an FE truck motor. Thanks
  #2 (permalink)
Old 05-09-2004, 08:58 PM
ML1983 ML1983 is offline
ML1983 is starting off with a positive reputation.
It really depends on what it came out of. If it was an F-500 up to F-800 then the engine is probably a 330, 361, or 391. I think the 401/477/534 were only used in the C-series and conventional cabs beyond the F-800.
  #3 (permalink)
Old 08-12-2004, 02:05 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
It Is A Ft Motor A Heavy Duty Version Of A Fe Motor
  #4 (permalink)
Old 08-13-2004, 10:59 PM
f600nightmare f600nightmare is offline
f600nightmare is starting off with a positive reputation.
its an ft they had 359 361 391 etc
Tags
engines, ford, identifying, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
