I know we've covered this several times in here. Try a search using " weigh" or "weight" and you should find it. The last time was about 4 mths ago....
My 56 F100 stock V8 stick weighed 3316 lb. If you swap the Y-Block and 3 speed for a 302/C4, the weight should be about the same. The Y-Block is heavier then a 302, and the C4 is heavier than the stock 3 speed.
