7.3 IDI fuel filter - Ford Truck Enthusiasts Forums
7.3 IDI fuel filter
Old 04-04-2002, 11:24 AM
Z28PULLER Z28PULLER is offline
Z28PULLER is starting off with a positive reputation.
7.3 IDI fuel filter
I bought a fuel filter for my 94 F-250 the other night. I got home and was ready to change the filter. I looked at the filter in the box and it really didn't look like the one already on the truck. I bought the truck used so I don't know a lot about it. The filter on it now has a drain looking thing coming out the bottom of it and a wire terminal that hooks to a wire also. What the heck is that stuff for? Did I buy the wrong filter or do I have to connect the new filter to this stuff? Anybody?
wesley
94 F-250 7.3 IDI 4X4 35" Mud Terrains
Old 04-04-2002, 02:55 PM
TLindquist's Avatar
TLindquist TLindquist is offline
TLindquist is starting off with a positive reputation.
7.3 IDI fuel filter
What that is, is the bowl to remove water from your fuel filter. Water is heavier than diesel and will accumulate on the bottom. The bowl has a drain valve (twist type) with a hose to drain off to the side and not allover your exhaust, heads, etc. The wire goes to your instrument panel inside the truck, which will light up if water is indicated inside the bowl. So you never have problems, buy fuel from stations that have a lot of business, this means the fuel is not siiting for a very long time underground and moisture doesn't have time to accumulate.
The easiest way i have found is to remove the whole fuel filter/seperator in one piece, then once removed from engine compartment, seperate the two pieces and put on new filter. When it's time to start the truck, you may have to crank it for a while (if mechanical fuel pump) to get the filter full of diesel.
Hope this helps, I was once in your shoes and now it's second nature.
Old 04-04-2002, 05:22 PM
therigwelder therigwelder is offline
therigwelder is starting off with a positive reputation.
7.3 IDI fuel filter
Old 03-17-2014, 02:19 PM
polarbear87 polarbear87 is offline
polarbear87 is starting off with a positive reputation.
The thing i find easiest to do is after i filled the fuel filter and bowl when it is in. To get the fuel to the filter, i bought a cheap tire air filler with detatchable hose and a screwed it off so i can use it on the screader walve and a boat primer bulb with hoses, and attach this to the schreader walve and pump this into a bottle until theres only diesel coming out, then i bleed nr 1,3, 5, 7injector try to start it and then loosen the nr 2, 4, 6, 8 injector until it idles like a clock in addition i added some small o-rings between the fastening bolt to the injector and the plastic return caps so they won't move loose, and to prevent leaking..
Old 03-17-2014, 04:13 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
you know the last post in this thread was almost 12 years ago, rite?
Old 03-18-2014, 10:41 AM
Quizzack's Avatar
Quizzack Quizzack is offline
Quizzack is starting off with a positive reputation.
I wonder how many times OP has changed his filter by now, if he still has the truck.
Old 03-18-2014, 10:42 AM
i ain't rite
i would say at least 12 times if he still has it.
but i doubt that since he has not logged on since 06-10-2004
Old 05-27-2014, 02:29 PM
Ray Vaughn Ray Vaughn is offline
Ray Vaughn is starting off with a positive reputation.
Unhappy Fuel Filter Light on Truck won't turn over
Fuel Filter Light on and Truck won't turn over!
93 f250 - It is actually being towed home as I write this but I was wondering what people's first thoughts were?
What should I check out? What can I try to do before I start replacing things?
Getting better at fixing this baby myself but the input from here always makes things simpler for me.
Thanks in advance
Old 05-27-2014, 03:06 PM
Stupidly, I didn't think of telling my wife to drain the filter - thought of it when she was half way home. Got it here - drained it and she started up no probs ....hoping that was it was.
Old 05-27-2014, 03:08 PM
You provably got trapped water in the filter thats why it lights up, or the sensor is bad and you may have a airleak from it what kind of filtwr ype du you have?? A spin on filter or filter media that you insert into the filter housing ??
Old 06-12-2014, 02:53 PM
Just confused now
f250 7.3
So the fuel filter (or so I believed ) was getting worse and worse and finally the truck didn't turn over.
Went and got a new filter (screw on - looks just like an oil filter - with a drain nut on the bottom) and once I got the air out of the system she roared to life.
No problems for three days - then a short period when 'water in fuel' & 'fuel filter' came on - cranked a couple seconds long - turned over no further problems that day.
It has, over the the last week and half, gotten worse and worse until today - once more, it simply won't turn over. Exactly the same as before I got new filter on.
Checked going from front to rear tank - no difference
No white (or any colour) belching from exhaust. Schirvner(?) value shows decent fuel pressure/quantity. 3/4 tank of fuel (1/2) tank put in Tuesday (this being Thursday) Injection pump new last new --- and YES - all the fuel lines ARE the old grey originals.
The thing that is really confuses me is the working great then quickly but incrementally getting worse.
Hoping you all can give me some good idea's over the next 24hr or so because the vehicle is at my-in-laws and will be going back over o further trouble shoot Sat afternoon.
Old 06-12-2014, 03:01 PM
i ain't rite
remove the fuel cap and try it.
i wonder if the tank vent is plugged and causing a vacuum in the tank preventing the pump from drawing fuel.
Old 06-12-2014, 03:17 PM
I had the same problem on my e350 7.3idi and changed the fuel filter but it returned, turned out i had to change o-rings on the injectors and replace the return caps and new fuel return lines, have not had any problems since,
But your problem could be the fuel tank selector valve, fuel filter bowl leaking air or the sealing o-ring on the fuel filter, if not check the fuel return caps for leaks or moist, it could be the o-rings on the injector or the return lines.
That is the most common cause usally, due to the heat and diesel eating away at the orings
Old 06-12-2014, 04:47 PM
thanks - jotting these down to take with me when I go back to the truck. Every bit of info helps
It's the 'getting better- then getting worse again bit by bit that confounds me. I'm even starting to wonder if the old filter was fine and it was something else - and when I changed the filter it did something which 'cleared' the system temporarily :\
Old 06-13-2014, 03:36 PM
how is it going ?? Have you found out anything yet??
84 6.9 to 94 7.3 idi turbo swap. fordf150f250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 10-22-2016 05:51 AM
84 6.9 to 94 7.3 idi turbo swap help! fordf150f250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-21-2016 12:47 PM
7.3 IDI Water in fuel switch wiring LustfulVengance 1987 - 1996 F150 & Larger F-Series Trucks 2 01-11-2016 08:14 AM
Where is the fuel filter sensor? Scaper Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-28-2012 06:37 PM
94 7.3 IDI Turbo......Won't Start...Help??? wesford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 11-06-2010 05:07 PM
Tags
73, filter, fuel, idi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
