7.3 IDI fuel filter
Well- I went back to the truck and first thing I did was try to it to start - without doing anything.... only to find out that now the ignition/starter relay wasn't working.
Bypassed it to try a couple of time - and found fuel is definitely getting past the filter. Also, now, I have lots of white smoke (which wasn't there before)
So while sitting doing nothing for early 48hrs -the relay went and now I'm getting white smoke -- still won't actually fire.
trying to get a new relay in to keep seeing if any answers become obvious -- but that's not working great as it stand.
this really just gets more bizarre as thing change for no quantifiable reason
Received 3,102 Likes
on
on
changed relay put in new plugs - hard first start then fine. later I started her up a bit of hesitation but started -drove 5 min / stop for 2. strats fine - did that again - fine.
Sits in drive way two days - starts hard but goes then NEW SYMPTOM - 4-5 times over a 45min drive at eighty, the speed stays same but rpm jumps from steady 1.5 to 2 --without speed change or noticeable tranny/gear issue.
Then after an hour drive total, parked for 25 min (hot day in sun) and same as before ---won't turn over as though not getting gas. (don't know a bout smoke color I'm not there wife is reporting) Fuel filter light was on - she drained some of the filter , light went out but still won't turn over.
Making no sence. Okay - then not. Change fuel filter- okay then not. Change glow plugs = okay then not. It just doesn't add up or make any sense ... may just have to throw hands in air and bring it to someone...can't afford to be off the road like this (or risk getting stuck far away again) any longer
on
ok, here is something else to try. when it will not start hot after driving for a while, pour cool, not cold water over the injector pump. if it starts up after this, the injector pump is bad.
fordf150f250
10-22-2016 05:51 AM
fordf150f250
10-21-2016 12:47 PM
LustfulVengance
01-11-2016 08:14 AM
rubberman56
02-20-2015 12:07 AM
