330 CID V8 in 1978? - Ford Truck Enthusiasts Forums
330 CID V8 in 1978?
Old 05-08-2004, 05:57 PM
akaFrankCastle's Avatar
akaFrankCastle akaFrankCastle is offline
akaFrankCastle is gaining momentum as a positive member of FTE.
330 CID V8 in 1978?
I was out looking at my future NP435 the other night. It is in what I believe to be a 1978 F600. The air cleaner on the engine says "330 XD". Anyone know if Ford ever made a 330 CID V8 prior to the 1997 5.4L Tirton debut?
Thanks,
Zac
Old 05-08-2004, 06:04 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
yes ford did make an old 330 ft motor and they were used in big trucks. The 330,361, and 391 were used for heavy duty applications.
Old 05-08-2004, 06:15 PM
would you know where I can find some specs on these engine? Horsepower ratings? Torque?
Old 05-08-2004, 06:39 PM
nope not really! They had 7.4 cr and had low hp and torque numbers.
Old 05-08-2004, 07:14 PM
1979ford's Avatar
1979ford 1979ford is offline
1979ford is starting off with a positive reputation.
I have a 1974 F-600 Grain Truck with the 330 HD, a 5+2 transmission, and an 18 ft. box on it. Getting pretty weak and I don't think they had very impressive numbers new. Does anyone know what engine family they are in?
Old 05-08-2004, 07:27 PM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
you might ask the guys on the 401,477, 534 CID forum.
330 isn't one of those engines, but they know medium duty truck engines pretty well.
Old 05-08-2004, 08:22 PM
they are the ft motors. Meaning ford truck.
Old 05-08-2004, 08:25 PM
76supercab2's Avatar
76supercab2 76supercab2 is offline
76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.
I believe internally they are similar to the FE family. Check in that forum.
Old 05-09-2004, 12:00 AM
kenmt kenmt is offline
kenmt is starting off with a positive reputation.
1978 F600 w/ 330 c.inch - 137 h.p.@ 3600rpm,250 ft. lbs. torque@2400 rpm
Old 05-09-2004, 12:05 AM
thats pretty weak!
Old 05-09-2004, 02:16 AM
fatherdoug's Avatar
fatherdoug fatherdoug is offline
fatherdoug is starting off with a positive reputation.
Weren't some of the big truck motors also set up for LPG fuel?
Old 05-09-2004, 05:19 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
There was a difference in the HP ratings for HD vehicles -v- cars and light trucks. In a car or light truck they rate them as peak HP while in a HD vehicle they rate it as continuous HP. A car or light truck engine will overheat and destroy itself if you try to get the peak HP ratings out of it for very long.
Old 05-09-2004, 09:54 AM
daveee daveee is offline
daveee is starting off with a positive reputation.
U-haul used the 330 XD in their F-350's throughout the 70's. I believe they used 359's in the F-600's.
Old 05-09-2004, 11:11 AM
I've been trying to look for aftermarket parts for this thing for a few days. Doesn't seem to be too much (if anything) available for this seemingly obscure engine. Everything I pull off of this truck is going to be free. Just wondering if it was going to be worth the hassle to throw this engine in another vehicle. Seeing how I won't be moving any grain in the back of my 66 Bronco, I think I'll just leave the engine where it sits and pull only the tranny.
Old 05-09-2004, 05:47 PM
sowcat sowcat is offline
sowcat is starting off with a positive reputation.
Ft
330's came as medium duty's and heavy duty's. the medium duty's had a cast crank and a waterpump like pickup truck FE"s. Heavy Duty's had a forged crank, a cast iron timing cover and a waterpump that was"flat". Both have FE dimensions,that would be one mother to put in a baby Bronco. Woody
1978 F600 dashpad old uhaul 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-29-2016 08:38 AM
1971 F-600 330 Engine Rebuild kit? ShockFox395 1967 - 1972 F-100 & Larger F-Series Trucks 4 10-27-2016 05:15 PM
330md 330hd blisstruck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 02-22-2015 12:37 PM
interchange xoloski FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 05-10-2012 12:23 PM
1976 3 ton w/ 330 v8 Sierra94_ 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-17-2003 10:55 PM
Tags
1974, 1977, 1978, 330, 330cid, cid, engine, f350, f600, for77, ford, motor, specs, truck, tune, uhaul, v8, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
