Hey guys, I'm pulling my hair out trying to find the GCWR on my 95 F-350 standard cab. I know the GVWR is 10000 (actually 9850), but can't find any literature on combination rating. Any help is much appreciated.
According to the 1996 F250/350 owner's guide, a regular cab F350 SRW 4x4 with a 460 (7.5L) and E4OD 4-speed automatic transmission has a GCWR of 15,000 lbs/ 6804 Kg with the 3.55 gears and 18,500 lbs/8392 Kg with the 4.10 gears. The same F350 SRW/reg cab 4x4 7.5L with the ZF S542 5-speed manual has a GCWR of 12,000 lbs/ 5443 Kg with 3.55 gears and 16,000 lbs/ 7258 Kg with the 4.10 gears. The codes on the door jamb sticker (under AX) for a limited slip 3.55 is C9 while a 4.10 is C5. For open diff, the codes are 39 for 3.55 and 35 for 4.10.
Thanks for the help guys. Mine has 3.55 's in the back so i guess 15,000 is where I'm at there. It would be easy if I had access to an owners manual, but mine seemes to have grown legs.....
