Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #151 (permalink)
Old 05-18-2004, 01:25 PM
jasfaa's Avatar
jasfaa jasfaa is offline
jasfaa is starting off with a positive reputation.
Quote:
Originally Posted by powerstrokedieselboy
Sorry to post right away again, but Bob I kind of got something like that in writing. The "GOOD" dealership i was at did put that the sporadic revving up and down was normal for this motor to do that and that ford didn't have a fix for this.
PSDboy
I have been having a rev up problem only when I have driven for awhile at a sustained speed and come to a stop. It revs up to 2,000 rpm's and back down. Is this what you are talking about or are you talking about the surge issue they had?
__________________
Current Vehicle
2008 F350 Crew Cab Long Bed 6.4L
No Mods
Past Vehicle
2004 F350 Crew Cab Long Bed 6.0L
Banks 4" Monster Exhaust w/Six Gun
  #152 (permalink)
Old 05-18-2004, 01:31 PM
jdadamsjr jdadamsjr is offline
jdadamsjr is gaining momentum as a positive member of FTE. jdadamsjr is gaining momentum as a positive member of FTE.
Jasff, this surging was corrected with one of the flashes...
Powerstrokedieselboy,
the dealership said it was normal ?
I promise you that's not Ford -
WE probably get along with Ford better than some of the dealers :-)
Don't I recall the Ford dealers sueing Ford a few years ago ?
I know if I have a problem with a dealership, I will try to work it out with them, if not, I will go to another dealer and see what treatment I get...
Then we start talking to Ford....
but just like ONE Kwik Kar oil change has ruined me from ANY OTHER Kwik Industries franchise because Kwik corporate chose not to respond to my complaint ! Eventually even 30 or 40 year customers can be forced to go elsewhere...
but I can tell u this, my Ex is the BEST travelling vehicle I've ever owned...
only problem is now it's ruined me for any other vehicle !!!
__________________
05 Ex 4x4 6L - GOS lite Harness,Hellwig, Walker BTM, SCT is all - 8.9 @ 75 1/8th!
http://video.thedieselgarage.com/Pla...ker&p=0:thumbs
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp Upgrade Turbo-back Exhaust, LOADED...
even goner-2002 4x2 7.3L Ex Limited
  #153 (permalink)
Old 05-18-2004, 02:11 PM
powerstrokedieselboy powerstrokedieselboy is offline
powerstrokedieselboy is starting off with a positive reputation.
Well it is stated on my serivce order as follows:
"Cust states that vehicle will rev up by itself appx 1,000 rpm to 1,200 rpm in drive and park, Verified concern. However per FORD info. This is a characteristic of this vehicle and no repair attemp is to be performed at this time."
This is what my last repair order said on it. What you think????
PSDboy
__________________
Thanks,
PSDboy
  #154 (permalink)
Old 05-18-2004, 03:22 PM
jasfaa's Avatar
[quote=jdadamsjr]Jasff, this surging was corrected with one of the flashes...
QUOTE]
I just had the flash brought up to date a week ago and it does a weird idle up when I stop after traveling for awhile. I am not sure it was the surge problem to begin with. It was almost like someone accidently left there foot on the accelerater when they pressed the clutch and the first few times it did it I thought maybe I had done that. After awhile though I realized it was doing it on its own. If it was only going up to 1200 rpm's I would not be as worried but it hits 2k when it does it. I am really happy with the truck except this unexplainable issue that I am not seeing posted anywhere else is really weird.
__________________
Current Vehicle
No Mods
Past Vehicle
  #155 (permalink)
Old 05-18-2004, 05:17 PM
Choctaw Bob's Avatar
Choctaw Bob Choctaw Bob is offline
Choctaw Bob is starting off with a positive reputation.
I was wondering if this was "NORMAL" than a new 04' 6.0 should do this on the lot, A?
What due you think of that Bob? Did Ford put themselves out on a line there??? Just wondering what ya'll think. The part where ford called htis normal is listed on my repair order also. So it is documented.
Take Care,
PSDboy
I think what Steve was relaying to us was that his service manager had said that ford had given up on fixing the flash issue. What that entails is much more complicated than what you are describing. I disagree that Ford has made a corporate decision to do that. It would be crazy. The problems are fixable.
I think what you are describing used to be (in the old days maybe 10+ years ago) called "romping". Probably every diesel then did some romping.
In the mid 1970s I ran a D-8H Cat dozer in a Gypsum strip mine. In the morning when I started it, it would romp for 1/2 an hour until it warmed up thoroughly.
It is wrong for them to assume that any kind of problem is "just the way it is". That is a cop-out because they don't how to fix it.
Try another dealer but call around and ask if they have a Ford certified Diesel Mechanic. Most dealerships have code readers and module changers. Not real mechanics.
__________________
03 6.0 SC Short bed 2WD Auto
Preditor, Gages, K & N FIPK
  #156 (permalink)
Old 05-18-2004, 05:21 PM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is starting off with a positive reputation.
Correct, the service manager said that "Ford would probably not do any more." We were talkig about my concerns on the negative effects of the the Oct. and Dec flash. I asked if he had spoke with Ford and he said yes and repeated that he didn't think they were going to do any more. He said if I came there, he would help me write the DSB.
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #157 (permalink)
Old 05-18-2004, 05:26 PM
If I were going to go for a new truck, I think I would wait until the 05s are out. They are supposed to be special.
__________________
  #158 (permalink)
Old 05-18-2004, 05:38 PM
SBV45's Avatar
Other than the results of the Oct/Dec flash, I like my truck. It runs great and is comfortable. It pulls my boat like there is nothing behind it. Yeah the 04 engines have a bunch of changes, but do the changes make that much difference? Some of us have early 03's that will run with the best of them. I know I have a good truck. Why jump into an 04 that might have a bunch of problems. I'll probably wait it out.
__________________
  #159 (permalink)
Old 05-18-2004, 06:29 PM
Quote:
Good for you. If I can get my flash saved to disk, I will give it to you. With the Predator in the 65 mode it drives perfect to me.
__________________
  #160 (permalink)
Old 05-18-2004, 07:51 PM
03f350crew 03f350crew is offline
03f350crew is starting off with a positive reputation.
My reving up problem was solved with the Oct. flash.
  #161 (permalink)
Old 05-18-2004, 09:28 PM
huntercgr's Avatar
huntercgr huntercgr is offline
huntercgr is starting off with a positive reputation.
I've read this a few times now and was wondering.... If they say it's normal, why would Ford say they don't have a fix?
__________________
04 350 6.0, Auto, Lariat, Crew Cab, short bed, white,tan interior,
  #162 (permalink)
Old 05-18-2004, 09:31 PM
Quote:
Just doublespeak
__________________
  #163 (permalink)
Old 05-18-2004, 10:33 PM
IB Tim's Avatar
IB Tim IB Tim is offline
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
Quote:
Originally Posted by Choctaw Bob
Just doublespeak
Isn’t that being able to speak out of both ends?
I have been accused of that capability..................only once
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #164 (permalink)
Old 05-18-2004, 10:37 PM
I have 3 ex wives who would testify that I have done so. That is why I'm familar with the term.
__________________
  #165 (permalink)
Old 09-15-2004, 09:45 AM
1999_Ranger 1999_Ranger is offline
1999_Ranger is starting off with a positive reputation.
I would wait for the 05
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
