CRACKED HEAD? Water blasting past everything
Old 05-07-2004, 11:53 PM
booneyrat75's Avatar
booneyrat75
booneyrat75 is offline
I have a car I'm working on for a friend and don't have a clue why an engine would literally blast water past the radiator cap when COLD and even out of the overflow tank and past the thermostat inlet hose at the clamp!!! The engine will be ice cold and send water everywhere like the thermostat is stopped up. We installed a new thermostat and found the same thing so we completely REMOVED the thermostat and, guess what... SAME DEAL!! Is this the result of a cracked head even though the oil pan has absolutely no water in it? PLEASE help me get this guy on the road. He's a Marine and this is his family's only mode of transportation. Thank you all so much, in advance!
Airborne. All the way!!!
SGT Stephen A. Green
Paratrooper, US Army
Old 05-08-2004, 09:27 PM
Dealford's Avatar
Dealford
Dealford is offline
Exclamation
The exhaust gasses are what is propelling the coolant out. A head doesn't always crack in an area where you get coolant in the oil.
Old 05-11-2004, 12:29 AM
booneyrat75
Thanks. I'm pulling the head in the next day or so and swapping on another. I'm keeping my fingers crossed on this one as the car seems to be CURSED!
Old 05-11-2004, 07:47 PM
Dealford's Avatar
Dealford
Dealford is offline
Thumbs up
Included in pride of ownership is the advantage of never having your tools rust.
Don't forget to flat file the deck & the head to check for high spots.
Good luck!
sixshootingexp
12-02-2012 09:44 AM
catman52987
09-19-2011 08:07 PM
booneyrat75
12-07-2004 03:30 PM
booneyrat75
17
05-13-2004 09:35 AM
Quick Reply: CRACKED HEAD? Water blasting past everything
