Thanks for the offer Ford61F500, but I'm guessing that it would cost an arm & leg to get it up to this neck of the woods, I have located a 351w engine and a T18 trans at a local scrap dealer who specializes in restorations. He will give me everything I need, engine complete with all attachments, a bellhousing and clutch, quaranteed to work, for $750 cdn.(that"s about $500 US}. The trans has provision for a PTO on the side. with the same 6 bolt pattern as mine but my PTO has straight cut gears and the T18's are helical, also my Pto is on the passenger side, the T18's is on the drivers side (I think) This could be a problem, maybe I won't have an operating dump box after all.This truck was last licensed in 1968. since then it has sat in a field. The hood was half open and the air cleaner missing, also the windshield shot out. The snow & rain went down the carb and dripped off the dash onto the shift boot which eventually dried out and cracked. Everythig else seems to be fine, full of grease where required, rusty but sound. I'm retired and have time to work on it. I found some tickets under the gas tank for purchasing 25 lb. blocks of ice, so I;m guessing it was used to deliver ice back in the days before refrigerators. Maybe I'll call it the Ice Wagon. Thanks again!
