possible Transmission Control Switch (TCS) problem
Old 05-07-2004, 03:46 PM
karmaz_payvment's Avatar
karmaz_payvment
karmaz_payvment is offline
Question possible Transmission Control Switch (TCS) problem
Hi,
I ran a test on my EECIV and it came up with a DTC concerning the Transmission Control Switch saying that it did not change state during the KOER test. I was wondering if there was a way to test this switch? Is it a common problem? I dont seem to be having any transmission problems at the moment, but i would like to find out why I'm getting this code. Thanks!!
marc
Old 05-07-2004, 06:19 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
I am not sure exactly what the transmission control switch is, but make sure you also state the year and some other specs that you know about your truck(year, engine size, type of tranny, f150, 250, etc.)
Old 05-07-2004, 07:40 PM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
It can only change state if you switched it on and off during KOER... IE you needed to turn the wheel for PSPS switch if equipped, hit Brake lamp switch for BOO test, and toggle the trans overdrive switch off and on.
Old 05-09-2004, 06:07 PM
karmaz_payvment
problem solved
That was the problem. I turned the wheel to aknowledge the PSPS and hit the brake for the BOO test but forgot to switch the O/D off and on. Oops....should've known better...thanks guys!
Odieds69
03-14-2016 04:10 PM
Jageesey1
12-23-2015 03:08 PM
theinrich
1983 - 2012 Ranger & B-Series
10-17-2015 03:06 PM
cornbinder
16
05-28-2014 10:26 AM
12valveEx
06-28-2013 11:50 AM
Quick Reply: possible Transmission Control Switch (TCS) problem
