Spark Plug Gap - Ford Truck Enthusiasts Forums
Spark Plug Gap
Old 05-07-2004, 12:33 PM
bent rim bent rim is offline
bent rim is starting off with a positive reputation.
Spark Plug Gap
Just wondering how critical gapping new plugs are vs installing straight out of the box in regards to power and mpg's.
Old 05-07-2004, 12:49 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Very, you need the correct gap.
Old 05-07-2004, 02:06 PM
acerockola77's Avatar
acerockola77 acerockola77 is offline
acerockola77 is starting off with a positive reputation.
Most of the time the plugs that I get already are set to the correct gap (well the specified gap for the truck).
Old 05-07-2004, 02:16 PM
Slade901's Avatar
Slade901 Slade901 is offline
Slade901 is starting off with a positive reputation.
I used to take the word of part clerk and telling me that it is already gapped to the right specs for my vehicle.
One day I checked the gap just to make sure and not all of them have the same gap and I have to adjust it myself.
Everytime I order spark plugs, I always tell them to write the gap specs on the side of the spark plug box and check it for myself.
Old 05-07-2004, 07:01 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
It can make a world of difference. The gap range is usually about 10% of the gap, and I always set it to the LOW end of the gap, I've found that the engine typically runs better that way. The voltage required to jump a given gap is a linear function, so a 10% increase in gap size requires 10% more voltage to jump the gap. But you should have plenty of voltage to spare if your ignition system is in working order. And, as the plugs wear, that gap opens up (albeit very slowly), so you may as well start on the low end of the range.
Jason
Plug gap dobenator 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-06-2016 01:06 PM
Spark Plug Gap Trevor1 1987 - 1996 F150 & Larger F-Series Trucks 3 12-08-2006 12:32 AM
Spark Plug Gap EXPLORER GUY Explorer, Sport Trac, Mountaineer & Aviator 4 12-01-2006 11:49 AM
spark plug gap for 93 explorer ssKable Explorer, Sport Trac, Mountaineer & Aviator 2 03-05-2005 01:46 PM
Spark plug gap?? elstx 1967 - 1972 F-100 & Larger F-Series Trucks 16 09-18-2003 06:17 PM
Tags
1987, 351w, 49, 49l, 96, duraspark, e150, ford, gap, ii, plug, plugs, size, spark, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
