How to replace tailgate handle on Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-06-2004, 10:39 AM
skincer skincer is offline
skincer is starting off with a positive reputation.
The handle that allows me to open my tailgate just broke and I ordered an aftermarket replacement. The original was plastic and the replacement is all metal. Can anyone tell me what's involved in installing the new one? Specifically, do I have to take that tailgate apart or can I do it from the outside of the tailgate? I see screw heads on the inside of the tailgate and I'm assuming that these would allow me to remove the inside of my tailgate.
Thanks.
Steve
Old 05-06-2004, 11:35 AM
Ranger8539 Ranger8539 is offline
Ranger8539 is starting off with a positive reputation.
Just remove cover , once you do that pretty easy..Hope this helps
Old 05-06-2004, 11:43 AM
Cover?
Quote:
What cover? Do you mean the inside of the tailgate? When I lift the handle, underneath I see a plastic "plate" that looks like it might be a cover?
Thanks.
Steve
Old 05-06-2004, 11:50 AM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
The one on the back side of the tailgate.
Old 05-06-2004, 11:59 AM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE.PSKSAM2 is gaining momentum as a positive member of FTE.
I'm confused too. I need to grease mine so that it doesn't break (very squeaky and tough to pull on). I took off the tailgate bedliner, but I couldn't see how to get to the mechanism.
-Jim
Old 05-06-2004, 12:15 PM
Ken00's Avatar
Quote:
-Jim
What year, not all of them have the access panel.
Old 05-06-2004, 12:44 PM
Quote:
Mine's a 2000.
Old 05-06-2004, 01:11 PM
PSKSAM2's Avatar
All mine are 1998's
Old 05-06-2004, 02:06 PM
Ken00's Avatar
There should be an access panel on 1998 & 2000, eight screws.
Old 05-06-2004, 02:15 PM
DainBramage's Avatar
DainBramage DainBramage is offline
DainBramage is gaining momentum as a positive member of FTE.DainBramage is gaining momentum as a positive member of FTE.
Every Ranger tailgate I've ever seen has the access panel.
Open the tailgate, take off whatever protector/bedliner type thing you have attached to the inside of the tailgate.
There should be a panel, just like described, 8 (I only remember 4, but, it's been a while), and boom, you're right there, easy access to grease, replace, stare, adjust, whatever floats your boat.
What year (if at all) did they stop giving you that option.
Old 05-06-2004, 02:20 PM
Ken00's Avatar
The older ones don't, I had a 1989.
Old 05-06-2004, 02:36 PM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
I have been thinking about this too. I have the 88' sans access panel. My handle was sticky so I was able to spray it and it still works but you have to lift up pretty hard to release. What do those of us with ancient Rangers do?
Old 05-06-2004, 03:50 PM
My 2000 has it , handle snapped and I replaced it.
Old 05-06-2004, 09:15 PM
Ken00's Avatar
You have to pull the linkage out, there's screws at the handle and latches.
Old 05-13-2004, 10:52 PM
pembquist pembquist is offline
pembquist is starting off with a positive reputation.
Source for new handle?
I have an 86 and the handles bent. To get it out you just take out 3 screws on the inside side of the tailgate and unclip these little brittle plastic things that secure the rods that go to the latchs from the handle. Thing is, does anyone know where to get a NEW one. Failing that, anyone know what the newest year that would fit would be?
Will a newer tailgate handle fit in older tailgates? DGB3 1999 to 2016 Super Duty 7 06-15-2015 09:36 PM
Trade tailgates - would like a 2015 without the step in white 2civicrr 6.7L Power Stroke Diesel 21 06-06-2015 08:42 PM
Tailgate Step Delete sgrol 6.7L Power Stroke Diesel 12 06-18-2012 02:29 AM
Tailgate step & handle??? ackeiyword 2009 - 2014 F150 27 05-18-2012 10:41 AM
Tailgate w/step question jshumadine 1999 to 2016 Super Duty 9 08-24-2010 11:30 AM
Tags
06, 1989, 2002, 2004, ford, handle, how, logo, mazda, metal, ranger, replace, replacing, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
