How much does a ranger weigh?
Old 05-06-2004, 08:56 AM
tchelseat's Avatar
tchelseat
tchelseat is offline
I just recently moved and I am about to register my car in my new state (well, pseudo-state, Washington DC). There is a difference in registration fees for cars weighing less than 3500 lbs and more than 3500 lbs. How much does my 1994 ford ranger (reg. cab, 4-cyl) weigh?
Thanks!
Chelsea
Old 05-06-2004, 09:40 AM
stRanger706's Avatar
stRanger706
stRanger706 is offline
less, id say around 3000
Old 05-06-2004, 05:49 PM
maticuno's Avatar
maticuno
maticuno is offline
Welcome to FTE, tchelseat!
My 98 Ranger, regular cab, 4 cyl came in at 3050 on the dot when I had to register it in California. I'd say about ten pounds of that was mud though.
Old 05-06-2004, 08:56 PM
MF11283's Avatar
MF11283
MF11283 is offline
hey, my 97 super cab 4.0 V6 ranger with a fiberglass shell on it weighs just under 3800 LBS, the shell alone is a little over 200 LBS
Old 05-06-2004, 09:48 PM
cnw4621's Avatar
cnw4621
cnw4621 is offline
Is that the ACTUAL weight of the vehicle or the manufacturer's rating? I know in MO it's the weight rating, not the actual weight of the truck that determines what plates you get, how it's registered, whether or not it's subject to emissions testing...-IKE
Old 05-06-2004, 09:50 PM
MF11283's Avatar
MF11283
MF11283 is offline
when my truck was registered in calif, previusly it was in orgeon, they made it be put on a scale before it could be registered, thats what Im basing my statement on
Old 05-06-2004, 10:05 PM
cnw4621's Avatar
cnw4621
cnw4621 is offline
Wow, didn't know they put it on the scale.... they sure don't do it in the State of Missouri, even though my truck was purchased in Indiana with an Indiana certificate of origin...
-IKE
Old 05-06-2004, 11:08 PM
Level2's Avatar
Level2
Level2 is offline
Where at in missouri are you cnw4621? I live just east of KC about 40 miles.
Old 05-07-2004, 12:20 AM
maticuno's Avatar
maticuno
maticuno is offline
They pick over your truck with a fine tooth comb if you register an out of state vehicle in California. You have to have it weighed by a state licensed Weighmaster, you have to have the vehicle inspected by a licensed member of the DMV, and you need to have it pass smog.
Old 05-07-2004, 11:41 AM
cary200's Avatar
cary200
cary200 is offline
Originally Posted by maticuno
They pick over your damn truck with a fine tooth comb if you register an out of state vehicle in California. You have to have it weighed by a state licensed Weighmaster, you have to have the vehicle inspected by a licensed member of the DMV, and you need to have it pass smog.
I'm getting ready to move back to Ca. I moved from Ca. to Colorado in 95. Are they making sure you pass all your OBD II readiness tests there? How often are they making you do smog now? In Colorado, it is every two years and your vehicle does not have to pass the Evap. test.
I quess maybe I'll have to take my topper off when I get there although I don't think it weighs more than 100 lbs. I've never heard of car needing to be weighed there. Hmm, you learn something new everyday now.
Thanks
Old 05-07-2004, 04:00 PM
maticuno's Avatar
maticuno
maticuno is offline
If your truck is set up for Cali. emissions standards, then you are good to go on registering it back here. They will just do the standard smog test, which is pretty inclusive. You have to have it done every two years. Because my truck is only federal emissions, they had to do an enhanced smog test on it when I first brought it in. Don't know why, they just did.
Old 05-09-2004, 07:03 PM
cnw4621's Avatar
cnw4621
cnw4621 is offline
Level 2: I live in St. Louis...
Paratrooper84
6.7L Power Stroke Diesel
43
02-24-2018 10:19 PM
84 f250 6.9
13
03-25-2009 06:37 PM
holmanb
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
07-19-2005 12:12 AM
banjopicker66
1997 - 2003 F150
11-02-2004 06:47 PM
Quick Reply: How much does a ranger weigh?
