How much does a ranger weigh? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-06-2004, 09:56 AM
tchelseat tchelseat is offline
tchelseat is starting off with a positive reputation.
I just recently moved and I am about to register my car in my new state (well, pseudo-state, Washington DC). There is a difference in registration fees for cars weighing less than 3500 lbs and more than 3500 lbs. How much does my 1994 ford ranger (reg. cab, 4-cyl) weigh?
Thanks!
Chelsea
Old 05-06-2004, 10:40 AM
stRanger706 stRanger706 is offline
stRanger706 is starting off with a positive reputation.
less, id say around 3000
Old 05-06-2004, 06:49 PM
maticuno's Avatar
maticuno maticuno is offline
maticuno is starting off with a positive reputation.
Welcome to FTE, tchelseat!
My 98 Ranger, regular cab, 4 cyl came in at 3050 on the dot when I had to register it in California. I'd say about ten pounds of that was mud though.
Old 05-06-2004, 09:56 PM
MF11283 MF11283 is offline
MF11283 is starting off with a positive reputation.
hey, my 97 super cab 4.0 V6 ranger with a fiberglass shell on it weighs just under 3800 LBS, the shell alone is a little over 200 LBS
Old 05-06-2004, 10:48 PM
cnw4621's Avatar
cnw4621 cnw4621 is offline
cnw4621 is starting off with a positive reputation.
Is that the ACTUAL weight of the vehicle or the manufacturer's rating? I know in MO it's the weight rating, not the actual weight of the truck that determines what plates you get, how it's registered, whether or not it's subject to emissions testing...-IKE
Old 05-06-2004, 10:50 PM
when my truck was registered in calif, previusly it was in orgeon, they made it be put on a scale before it could be registered, thats what Im basing my statement on
Old 05-06-2004, 11:05 PM
cnw4621's Avatar
Wow, didn't know they put it on the scale.... they sure don't do it in the State of Missouri, even though my truck was purchased in Indiana with an Indiana certificate of origin...
-IKE
Old 05-07-2004, 12:08 AM
Level2's Avatar
Level2 Level2 is offline
Level2 is starting off with a positive reputation.
Where at in missouri are you cnw4621? I live just east of KC about 40 miles.
Old 05-07-2004, 01:20 AM
maticuno's Avatar
They pick over your truck with a fine tooth comb if you register an out of state vehicle in California. You have to have it weighed by a state licensed Weighmaster, you have to have the vehicle inspected by a licensed member of the DMV, and you need to have it pass smog.
Old 05-07-2004, 12:41 PM
cary200 cary200 is offline
cary200 is starting off with a positive reputation.
Quote:
Originally Posted by maticuno
They pick over your damn truck with a fine tooth comb if you register an out of state vehicle in California. You have to have it weighed by a state licensed Weighmaster, you have to have the vehicle inspected by a licensed member of the DMV, and you need to have it pass smog.
I'm getting ready to move back to Ca. I moved from Ca. to Colorado in 95. Are they making sure you pass all your OBD II readiness tests there? How often are they making you do smog now? In Colorado, it is every two years and your vehicle does not have to pass the Evap. test.
I quess maybe I'll have to take my topper off when I get there although I don't think it weighs more than 100 lbs. I've never heard of car needing to be weighed there. Hmm, you learn something new everyday now.
Thanks
Old 05-07-2004, 05:00 PM
maticuno's Avatar
If your truck is set up for Cali. emissions standards, then you are good to go on registering it back here. They will just do the standard smog test, which is pretty inclusive. You have to have it done every two years. Because my truck is only federal emissions, they had to do an enhanced smog test on it when I first brought it in. Don't know why, they just did.
Old 05-09-2004, 08:03 PM
cnw4621's Avatar
Level 2: I live in St. Louis...
How Much Does Your Truck Weigh ?? Paratrooper84 6.7L Power Stroke Diesel 8 10-01-2011 07:43 PM
Can someone tell me how much my truck weighs ? 84 f250 6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 03-25-2009 07:37 PM
02 F350 CC PSD AUTO WEIGHS 7800 lbS.? holmanb Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 15 07-19-2005 01:12 AM
Does my truck have the factory towing package? banjopicker66 1997 - 2003 F150 2 11-02-2004 07:47 PM
Tags
1987, 1994, 2004, 25l, cab, empty, ford, ranger, reg, regular, supercab, unloaded, weigh, weight, wiegh
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
