Powerstroke foaming problems with Chevron Delo 400 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-15-2002, 02:54 PM
powerstroker250 powerstroker250 is offline
powerstroker250 is starting off with a positive reputation.
Old 05-16-2002, 04:22 AM
rx2tee rx2tee is offline
rx2tee is starting off with a positive reputation.
Post Powerstroke foaming problems with Chevron Delo 400
Has anyone experienced any foaming problems in a Powerstroke due to using Chevron Delo 400 15w-40? A Service Dept. Employee at my local Ford Dealer stated that he had seen several cases of performance problems caused by foaming and Delo was usually the oil used. My 2002 F-250 has 4000 miles on it and I changed the oil and filter at 3000, using the Delo 400. My plan is to change oil every 2500 miles. I am planning on letting the dealer do the service at the 5000 mile interval and I will change it at the half way point.
I think this person at the dealer is just trying to sell oil at $3.10 per quart. At Costco I can buy 6 Gallons of Delo 400 for $33-34. I can't see paying more than $3 a quart for conventional oil.
Thanks,
Randy
Old 05-16-2002, 04:48 AM
The Diesel Dude The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
If you experience foaming it will probably manifest itself as rough running (mostly at idle or just past idle upon acceleration). If that happens, get some anti-foam additive from the International dealer in your area (don't get it from Ford because they will rip you off on the price) and use a different brand of oil at the next oil change. I seriously doubt that it will be necessary to change brands.
Old 05-16-2002, 06:31 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
I think Joe can verify this, but any oil will foam if you've got too much of it in the crankcase, and the crankshaft is stirring it up for you, basically turning your oil pan into a blender.
Old 05-16-2002, 10:23 AM
odie780 odie780 is offline
odie780 is starting off with a positive reputation.
Just kind of wondering why you plan on changing you oil so offten? I am useing Shell and change every 5 to 7 K and never had any issues with rough idel or any other symptom of oil foaming.
Old 05-16-2002, 11:43 AM
spartamouse1 spartamouse1 is offline
spartamouse1 is starting off with a positive reputation.
we use motorcraft 15w40, that is what ford and navistar worked together to design. dont know about the oil prices in your area but we sell it for $6 a galion. there are some other good oils but that oil was formulated just for the powerstroke? hey joe, don't go to the ford dealer to buy the addative they will rip you off??? ford does not even make the oil defoamer only navistar does.
Old 05-16-2002, 01:48 PM
We were doing some oil analysis research just this week with an engine we were running on the dyno for a 100 hour part load test (no oil change during the 100 hours) and I noticed when I checked the oil it had some bubbles in it. So, with the engine running, I added 70 CC of Lubrizol brand of anti-foam additive and by the time I had screwed the cap back on the oil pressure came up 2 PSI. This stuff really works! I also noticed that at the end of the run the oil was very runny and watery (cold), hence I reccommend changing the oil at no greater than the interval listed in the owners manual, even if you are using synthetics. Oil may not "wear out" but it becomes useless for the purpose for which it was created after a period of time.
Old 05-17-2002, 08:59 AM
did you notice at what point the oil started to bubble? was told by navistar that even the motorcraft oil will foam at 2500 miles. was told at that point is where you are supposed to put the addative it.
Old 05-17-2002, 10:01 AM
I've been using Delo 400 for 18 years with NO problems.
Les
E99 powerstroke leaking oil Powerstroke9292 1999 - 2003 7.3L Power Stroke Diesel 6 06-15-2015 01:02 PM
1996 powerstroke bad head khaleowen 1999 to 2016 Super Duty 0 03-28-2014 02:08 AM
PowerStroke Turbo Boost FTE Ken 1999 - 2003 7.3L Power Stroke Diesel 12 10-09-2010 08:33 PM
02 powerstroke waterpump replacement jkarne 1999 - 2003 7.3L Power Stroke Diesel 13 05-26-2010 04:29 AM
fastest powerstroke glasseater General Diesel Discussion 7 03-08-2007 08:41 PM
Tags
1996, 1997, 400, 400le, 73, change, chevron, delo, foam, foaming, ford, oil, powerstroke, problems, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
