Everyone with High Idle Please Read!! - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-03-2004, 03:52 PM
CMazz CMazz is offline
CMazz is starting off with a positive reputation.
Exclamation Everyone with High Idle Please Read!!
I came across this TSB while searching for more information on the Ranger High Idle Problem. I don't see why this TSB can't apply to other year models but here it is.
High Idle TSB 00-3-5
<HR>
00-3-5, Publication Date: JANUARY 31, 2000
FORD:
1998-99 TAURUS SHO
1998-2000 RANGER
ISSUE:
A high idle may occur on some vehicles. This may be caused by a poor electrical connection at the wire harness (-12B637-) to Throttle Position Sensor (TPS).
ACTION:
Splice into wire harness (-12B637-) just after the TPS with TPS Connector High Idle Service Kit. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Verify the concern vehicle exhibits a "high idle" condition when depressing the clutch or shifting between gears for the Ranger or when shifting between Park and/or Neutral for Taurus SHO. If high idle condition is not exhibited, proceed with other driveability diagnostic fix procedures. If condition is present, obtain a High Idle Service Kit (XF1Z-15K607-AA) and proceed by following the instructions found within the service kit.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emission Warranty Coverage
DEALER CODING
OASIS CODES: 203200, 617400, 619400
Old 05-03-2004, 09:45 PM
maticuno's Avatar
maticuno maticuno is offline
maticuno is starting off with a positive reputation.
Thank you so much! I had seen this TSB a long time ago, but I couldn't find it after that! Hopefully the dealer will sell me the kit...
Old 05-03-2004, 11:55 PM
Your welcome!!!
Old 05-04-2004, 02:05 AM
Caplax40 Caplax40 is offline
Caplax40 is starting off with a positive reputation.
What RPM is considered to be a "high idle"?
Old 05-04-2004, 06:08 AM
Depends...800-1200 is usually about normal on my rangers. This TSB is for the surging idle that occurs when you are shifting between gears or coming to a stop light/sign and your idle jumps to 2500-4000 with the clutch in. Does the same for an automatic but I notice it more since I have a manual.
Old 05-18-2004, 05:57 PM
elcdogo elcdogo is offline
elcdogo is starting off with a positive reputation.
wouldn't it be easier to replace it?
Old 05-18-2004, 06:25 PM
maticuno's Avatar
It probably would be, but some slide-rule toting bean-counter at Ford probably decided it would be more economical to provide a service kit instead of a new wiring harness. As long as it works...
Old 05-21-2004, 04:52 PM
darkengineering darkengineering is offline
darkengineering is starting off with a positive reputation.
Has anyone tried this fix yet? I've got the 40 mph idle going on.
I'll clean the plug and connections this weekend and see if that helps, but I'm hear from a user of this service kit.
Thanks
Old 07-25-2004, 01:43 PM
rhubarb rhubarb is offline
rhubarb is starting off with a positive reputation.
does this apply as well?
i have an 86 ranger 2.9 5 speed.....mine just high idles all the time...i wonder if that applys to me?
Old 07-25-2004, 01:55 PM
BigBlockGuru's Avatar
BigBlockGuru BigBlockGuru is offline
BigBlockGuru is starting off with a positive reputation.
Some of your "high-idle" conditions are occuring probably because your temperature gauge sending unit is malfunctioning and sending a cold signal to your ECU. Therefore, the ECU is interpreting it as being a cold motor and needing to richen the mixture and raise the idle to speed the warming up of the motor. I replaced mine and the thermostat and it fixed my problem on my 93.
Old 07-25-2004, 03:24 PM
Hank85713 Hank85713 is online now
Hank85713 is gaining momentum as a positive member of FTE.
I have a 94 4.0 5sp and have the high idle problem. I have changed the TPS and the IAC and it still had the problem. We did some trouble shooting and it seems that there is a wire problem down someplace in the wire loom. Anyhow I have disconnected the IAC and it runs just fine. With or withouf AC on it idles around 800 rpm.
Old 07-25-2004, 09:59 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Vacuum leaks can cause idle problems.
Ford 4L Engine Decarbon TSB 96_4wdr Aerostar 0 05-08-2013 04:13 PM
TSB 11-10-10 frt2599 6.7L Power Stroke Diesel 5 10-31-2011 07:42 PM
Transmission is Squawking Again! berry1234 2007 - 2014 Expedition & Navigator 0 09-14-2011 01:49 PM
Cleaning EGR New TSB 07-21-9 blackhat620 6.0L Power Stroke Diesel 0 10-17-2007 03:03 AM
TSB 07-16-3 (F-450 P/U Axle Whine Noise) PowerStrokeHD 6.4L Power Stroke Diesel 2 08-02-2007 04:27 PM
Tags
2000, 40, 86, 94, 98, ford, high, idle, mr2, neautral, park, races, ranger, shifts, toyota, xf1z15k607aa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
