oil pressure sending unit - Ford Truck Enthusiasts Forums
Old 05-02-2004, 11:52 PM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
Im going to install a few autometer gauges in my 2000 F-150 4.6. i was curious about where the oil pressure sending unit is. i know its supposed to be on the drivers side of the engine toward the pullys. I got under and looked for a bit and couldnt find it. is it somewhere else was i misinformed? also i hear about people installing a "t" fitting so that the factory light would still work. any info on how to wire this and what they mean by t fitting. is it something you buy or is it just a t junction in the wiring? thanks for any help
Old 05-03-2004, 06:57 AM
stantojl stantojl is offline
stantojl is starting off with a positive reputation.
On my 97 4.6 It is on the bottom of the oil filter housing. If you pull the oil filter off you should see it. Not sure about "t" fitting but that is a good idea.
Old 05-03-2004, 07:05 AM
kbkid kbkid is offline
kbkid is starting off with a positive reputation.
Thats excactly where mine is on my 01 screw, I just changed it last weekend. Make sure you remove the oil filter first.
Old 05-03-2004, 10:31 AM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
If yours is like mine, the oil filter casting has an additional port with a pipe plug in it. This is apparently for use on other models or for mechanical oil pressure testing. I found it easier to use that instead of messing with the factory sensor.
All these fittings are usually regular 1/8" pipe threads. You can buy fittings at Home Depot.
Old 05-03-2004, 07:10 PM
Fordtech1's Avatar
Fordtech1 Fordtech1 is offline
Fordtech1 is starting off with a positive reputation.
I agree with MrBSS, it would be easier if you can install the guage without messing with a tee. The T fitting is a two port fitting allowing two senders to read from the same outlet, screwed into the oil passage and having two places to install items, one, the original sender and two, the new one, leaving the factory unit to continue to function.
Old 05-11-2004, 03:13 PM
v8xploder's Avatar
so there is a 'port" on the factory oil filter casting, that i can screw my automeeter sending unit into? with out touching the factory sending unit?
Old 05-11-2004, 03:32 PM
On my 97 4x4 4.6 the extra port is on the bottom of the housing. I believe it can be used to bleed air. On my truck the port is almost impossible to get to. There is about a half inch of clearence between it and the front pumpkin. Not sure about the size, probably quarter inch pipe threads.
Old 05-24-2004, 12:51 AM
94F150-408 94F150-408 is offline
94F150-408 is starting off with a positive reputation.
Using a iron tee is a real simple procedure and it will let you use both gauges. Just use a 1/8"( I believe this is the size, bring your sender with you or measure it before you leave) pipe thread tee and screw it into the block where your existing sender is and then screw the two sensors into the other two ends of the tee. Dont forget to use a sealer on the threads. You can use bras or stainless also but you probably will have to use some sort of dielectric paste to keep from having some electrolosis action happen.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
