12V questions
I have 12V in a 51F1, but not GM single wire set up. The gas gauge was the only one I cared about, and an electrical shop sold me a resistor(?) to put in the line under dash prior to the gauge. The battery charge/discharge gauge needs no adjustment, doesn't care what voltage going through the line. I use an aftermarket gauge set for oil pressure, water.
I've used just 1 resistor for all the gauges since their ran in series with each other, as well as a resistor for the ignition circuit "because of the points."
I've done something different tho on the charging & starting catagory, I took my Starter & Genorator to a local repair shop & had them rework them to function as 12V units...
I have a GM alternator mounted on my flathead six. Was not hard to do. First I welded up a bracket that bolted to the stock generater holesin the block. If you can't make up a bracket, you could probably find a chrome universal bracket. I then used an aftermarket adjusting bracket attached to a water pump bolt.
For a pulley, the good news is that the wide belt pulley from the original six volt unit fits and works perfectly with the GM alternator. If you don't have the original, look for a wide pulley at a electrical repair shop.
For wiring, big terminal to battery, another lead to ignition and the third to idiot light.
Hope this helps
Hope this helps
