visual clues it is 6v or not
hello all, im in the process of looking at 55 f100. im on the east coast and the truck is on the west coast. the owner is not sure if its 12v or 6 volt system(he never had a battery in it). my question is can you tell visually by looking at the coil, voltage regulator, or starter solenoid whether its 6v or 12v. i have pics of the engine bay and those are all i can see.
thanks
kevin
thanks
kevin
Tell him to look for an ignition resistor on the line from the ignition to the coil. Usually an oblong ceramic box (3/4"x3") with a coil of fine wire around a piece of what looks like asbestos cord. There should be a wire terminal on each end. This reduces the 12V to 6.4V at the coil - keeps from burning up the points.
A generator is round cylinder about 5"x12" long and has 3 wires on the back end. Alternator is about 8" across and 5" deep and probably has one wire off the back.
Only reliable way to tell is to run it and measure voltage at the battery.
