Starting Problems in 98 F150 - Ford Truck Enthusiasts Forums
Old 05-01-2004, 05:38 PM
Tony G. Tony G. is offline
Tony G. is starting off with a positive reputation.
98 F150 4wheel drive, a/t, 5.4 L
Everytime I turn key to start, Fuse #20 (starter interrupt relay) blows. Sometimes will start, other times blows fuse. Had the starter tested and checked out OK and replaced starter selonoid/relay on fire wall--still have problem. Any suggestions?
Old 05-01-2004, 06:41 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Are you sure its fuse 20? Im showing that for manual transmission only and fuse 21 is a 15 amp for starter interupt. Also makes a difference if it has RAP module for vehicle security.
Old 05-01-2004, 06:47 PM
Sorry--it is 21 not 20. It's a 15amp--my mistake. I don't know if it has RAP. Bought it used and don't have any keyless entry. What is the RAP and where would it be??
Old 05-01-2004, 06:53 PM
RAP module is Remote Antitheft Personality module, a beige colored module mounted to the inside firewall all the way to the left side of the dash. Looks like that circuit also loops back through the clutch switch bypass and back through fuse 20 and on to the PCM. Kinda hard to tell where the problem might be here. May possibly be a wiring harness burn through on the exhaust pipe on the passenger side. The harness has a bad habit of falling off its retainer and landing down on the exhaust manifold or egr tube and getting burned through and causing a short. The intermittent fault may be leaning to such a problem. The circuit also is tied through the GEM module, so be also mindfull that the F150 is prone to water leaks from the windhsield and often causes shorts in the interior fuse panel and Gem module as a result. Being a recent purchase there is no telling what you may find.
Old 05-01-2004, 07:00 PM
I pulled the wiring harness from the starter all the way up to the starter selonoid on the firewall--no burn through spots. Retaped, resealed it, reinstalled--no bad spots on that. Went up under dash--no burned wires. Thanks for the help--I'll keep looking.
Old 05-01-2004, 07:01 PM
There is an off chance that relay is shorting internally itself. Wouldnt hurt to swap it out with a known good one.
Old 05-01-2004, 07:06 PM
I'll give that a try--Thanks!!
Old 05-01-2004, 07:50 PM
WHich relay--I already replaced the one on the firewall that goes directly to the starter?
Old 05-01-2004, 08:00 PM
I was referring to the starter interupt relay. But I have another view of this circuit from another section of the EVTM. Looks like it actually goes thru the Trans range sensor. You may have a short in it. Pull the connector and look to see if its full of water, oil, or mud. The sensor itself could be shorting or any of the wiring up to it.
Here is the diagram for without rap module.
Old 05-01-2004, 08:03 PM
And this is with RAP module
Old 05-01-2004, 08:17 PM
I'll try that tomorrow morning--thanks for all your help. I'll let you know how it turns out.
Old 05-02-2004, 12:36 PM
can't find anything wrong with wireing to trans sensor. any other suggestions?
Old 05-02-2004, 12:44 PM
Sometimes you just have to reproduce the short and trace the circuit while it is shorted.
Old 05-02-2004, 12:53 PM
Thanks for the help, i'll try to trace the circut from start to finish.
Old 05-02-2004, 05:29 PM
I found the problem--it was the wire harness that runs down the passenger side firewall and goes up over the transmission where the exhaust and transmission come together--the wire harness touched the exhause pipe and melted a spot. I found it by tracing the transmission sensor wire from the transmission wire back up toward the engine. I appreciate all the help from Homerwinzlow--hope I can help you sometime. Thanks!!
92 F-150 starter wont disengage m.collins 1987 - 1996 F150 & Larger F-Series Trucks 36 04-16-2015 11:42 AM
STRANGE ISSUE 1998 F-150, 4.2L V6 Starter issues 98F150on33s 1997 - 2003 F150 6 11-26-2014 11:28 AM
98 F150 Won't start triplehellcat 1997 - 2003 F150 9 01-04-2014 06:13 AM
Keeps blowing starter fuse renchr56 1999 - 2003 7.3L Power Stroke Diesel 1 08-10-2012 08:50 AM
starter relay fuse TOUGHLover Ranger & B-Series 2 12-05-2002 06:13 PM
Tags
98, burn, burnt, bypass, circuit, diagram, elec, f150, ford, harness, module, rap, raps, solenoid, starter, transmission, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
