Vibration at idle...
My 1998 5.4 has started vibrating a little when you are at a stop with it in gear. It doesn't seem to do it when you are not in gear. The vibration pulsates. I had an O2 sensor problem that I thought was causing it. After fixing the O2 sensor issue, the vibration is still there, but not as harsh. There is no noticeable miss and I haven't had the check engine light come on. I have 93,000 miles on it and I have yet to change plugs. Any ideas? Or, should I change the plugs and see what happens?
