Head Torque for 4.2 - Ford Truck Enthusiasts Forums
Head Torque for 4.2
Old 04-30-2004, 07:34 PM
Binder Guy Binder Guy is offline
Binder Guy is starting off with a positive reputation.
Head Torque for 4.2
I am looking for the proper torque for the heads on 4.2 V-6's, a friend of mine has had one rebuilt, and doesnt know the torque specs.... found the specs but the book I found listed the head bolt torque at 36 ft-lbs... that seems awful light. What do you guys think?
Thanks for any help.
Tim
Old 05-04-2004, 05:55 PM
F1Frankie's Avatar
F1Frankie F1Frankie is offline
F1Frankie is starting off with a positive reputation.
Sorry. i hate to leave you hanging with no replies...but I really have no idea. I would suggest going to your local library and checking out a Chilton or Hayes if they have one. Most do. Sorry I am not much help...
Old 05-05-2004, 02:03 AM
kellendv kellendv is offline
kellendv is starting off with a positive reputation.
torque specs: FT-lbs unless otherwise indicated
cylinder head bolts (oiled)
step 1...............................168 in-lbs
step 2...............................29
step 3...............................36
caution: when following the torque sequence for the V-6 engine, at step 4 do not loosen all the bolts at the same time or the gasket will not seal properly. loosen the first bolt in the sequence, tighten it to final torque (steps 5 and 6) then go to the next bolt in the sequence, loosening and tightening the bolts untill the sequence is completed.
step 4..............................loosen 3 turns ( do not loosen all bolts here. follow caution)
step 5
long bolts..................30 to 36
short bolts.................15 to 22
step 6(all bolts).................tighten an additional 175 to 185 degrees
get yourself a haynes manual! as i was told to do recently.....they are invaluable, and interesting
Old 05-05-2004, 09:20 PM
Thanks Guys
I will forward this to my friend, and see if he has come up with some specs as well.
Thanks
Tim
torque specs timf150 Excursion - King of SUVs 2 04-02-2012 04:34 PM
need head torque and rod torque specs eduardoCam00 6.4L Power Stroke Diesel 1 11-16-2010 09:17 PM
351W Torque Specs briank Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 10-30-2008 07:29 PM
1995 F150 Wheel Bearing Torque Specs slund42 1987 - 1996 F150 & Larger F-Series Trucks 3 06-18-2006 07:26 AM
Looking for 4.2l head bolt torque specs wpelletier 3.8 & 4.2L V6 1 03-14-2006 11:58 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2000, 42, 42l, 42v6, 97, bolt, bolts, f150, ford, head, headbolts, heag, specs, torque, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
