FE bellhousing vs. MEL bellhousing
No. The MEL bellhousing is elongated and bolts to a 429/460 (aside from it's obvious purpose.) That's the purpose of the extra pattern in the 385 block. I never knew that until somebody posted a pic recently. It uses only one of the top bolts, and slopes down at a sharp angle across the back of the block.
The ’58 –’62 MEL blocks have the same bell as the FE. The ’63 – ’65 blocks have a lower starter mount and a different dowel pin so they are not a direct bolt on to the FE bell but can be made to work. The ’66 – ’67 462 has a dual hybrid pattern of the earlier ’63 – ’65 and the 385. The block has an extra hole and a cast bracket that lets it mate to the 385 bolt pattern or the earlier pattern.
Wow. You guys always impress me with your knowledge, but this time you've suprised me.
The application here is bolting a MEL into an mid/late 50's F100, but the info also applies to other applications. I was conversing with a fella that has a MEL in his 57 F100. It's using a stock FE truck bellhousing, which allows the use of the bellhousing mounts.
Now I'm wondering what was being used for a flywheel. I'll bet the early MEL is compatible with the FE flywheel. A better choice would have been MEL/FE truck automatic bellhousing/FMX. I'll bet that MEL was a torque monster.
You're right the MEL and FE flywheels are compatible in fact they're the same although you don't see too many MEL's with sticks these days. I'm trying to remember what tranny they used, I think the 383 was offered with the Borg-Warner T-85 overdrive trans. MEL engines were the hot ticket for swapping back then but they were just called the Lincoln motor. Oh, FE motor mounts fit too.
Hey we all learn from each other, that's what so great about these boards!
Originally Posted by 390cobrajet
dont they have a shorter stroke and bigger bore compared to most other engines? so in my mind that would equate to high horsepower capabilities, right? so what was the bottleneck on these engines?
MEL's used Turbodrive on some engines, MX Cruise-O-Matics on others. The 1959/60 T-Birds offered the 430 as an option. Only the MX Cruise-O was available, no manual transmission was offered.
B8A-6375-B .. Flexplate ~1958/60 332/352/430 ~ 153 teeth / 14.96 O.D. / (16) 17/64" bolt holes.
1959: 430: B&S 4.30 x 3.70 / Compression Ratio 10.0:1 / 310 HP @ 4100 RPM
1959: 383: B&S 4.30 x 3.30 / Compression Ratio 10.01:1 / 322 HP @ 4600 RPM
