Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-07-2002, 02:39 PM
wildjon300ci is starting off with a positive reputation.
HELLLLLLPPPPPP!!!! Sick Powerstroke!
My dad's powerstroke is sick. It has a definate miss and the SES light comes on when it happens. I'm thinking it could be a bad glowplug because once the engine heats up it'll go away until it is allowed to idle or run at a slow speed. When I load the engine (I.E. up a hill in overdrive), once I hit the top and take the load off the engine, it'll quit missing and the SES will go off. It's like trying to start a cold gasser with no choke, you gotta play with the throttle to make the cylinder hit.....Anyone else have any ideas, I'm gonna try to have the codes read sometime soon, hopefully tommarow.
P.S. The oil was missing only two quarts (about 1200 miles 'till oil change time) and I topped it off just to make sure it wasn't that...and I have already ruled out bad diesel, two full tanks gone.
__________________
1986 Bronco 4x4 EFI 302
Stock...for now
Wide-ratio C6 :evilgrin:
351 waiting to be stuffed in
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-07-2002, 07:15 PM
The Diesel Dude is starting off with a positive reputation.
If your "service engine soon" light has been on then there is a code that has been set in the computer. You need to retrieve the codes from the computer and service the first one first. Your type of problem is the easiest to deal with because the computer tells you right where to look.
  #3 (permalink)
Old 07-08-2002, 07:08 PM
Well, I know know the problem, which is what I feared. The #7 injector has died. The truck is only 8290 miles outta engine warrenty. Oh well, I guess that's just how life goes.
__________________
Stock...for now
  #4 (permalink)
Old 07-08-2002, 07:32 PM
What is the year and mileage of your dad's truck?
  #5 (permalink)
Old 07-08-2002, 07:39 PM
1999.5 F-350...The mileage is 108,692 miles...
Can you check it out? The engine codes are KE 002 BC
0976283
Built? 11 Mar 99
__________________
Stock...for now
  #6 (permalink)
Old 07-09-2002, 01:53 PM
I can (and will) check your serial number in our data base but it is unlikely that there is anything there that is pertainent to an engine with 108,000 miles on it. Your truck has the new style injectors in it, which surprises me that one has crapped out on you.
  #7 (permalink)
Old 07-09-2002, 02:08 PM
If you are going to change this yourself, be sure to drain the rail before you remove the injector. If you don't, you run the risk of hydra-locking the cylinder and bending the connecting rod.
  #8 (permalink)
Old 07-09-2002, 02:55 PM
sthoge is starting off with a positive reputation.
Joe,
Do you have to drain both rails? (Fuel and HP oil)
Steven Hogeweide
2000 F350 XLT PSD 4X4, 6spd, ESOF, 4.10ls, Super Cab Dually, Tow Pkg, Camper Pkg, Off Road pkg, Western Diesel Power Chip, AutoMeter EGT and Boost gauges.
  #9 (permalink)
Old 07-09-2002, 07:17 PM
Steve:
I've never done one in the truck before but I don't think so. Drain the H/P rail (after you remove the drain plugs you'll need to take out one of the cross drill plugs on top of the rail or it won't drain) and remove the lower injector bolt, push the injector clamp forward (toward the intake side of the head) and pry the injector up enough with a screw driver so that you can lift it right out. When you get ready to pull the injector out of the bore, have the new injector in your other hand and when you pull the old one out, stuff the new one in right away, that way you'll minimize the fluid entering the cylinder (we can change them at the plant that way without draining either rail but it is a lot easier working on the engine when it is not in the vehicle).
I checked your serial number in our data base and, as you indicated, it was built 3/11/99, went straight through the system with no defects. The horse power and other performance characteristics have all been down loaded to a system I don't have access to.
  #10 (permalink)
Old 07-09-2002, 09:46 PM
Thanks man.......The new injector has been put in and the ole' girl is back to herself. The only problem is that $450 has left the building. :-staun
__________________
Stock...for now
  #11 (permalink)
Old 07-09-2002, 10:32 PM
twbuild is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
