What years interchange????? - Ford Truck Enthusiasts Forums
Old 04-29-2004, 11:15 AM
nate_o23 nate_o23 is offline
nate_o23 is starting off with a positive reputation.
I recently bought a 89 F 150 2WD off a guy who had apparently ticked off the wrong people. The windshield, side glass, rear glass, taillights and headlights are all broken. What year/models will interchange with mine?? I have an old (probebly early 80s) Ford van sitting out back, will the windshield and side glass interchange?? Thanks for any help.
Old 04-29-2004, 12:57 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
80-96 F series glass should fit and 88-91 lights. I doubt if you can use anything off an E series.
Jim
Old 04-29-2004, 01:10 PM
jason_2674 jason_2674 is offline
jason_2674 is starting off with a positive reputation.
Red face
I once asked the same ? think i was told 87 too 95 where some what inter changeable in most parts..
Old 04-29-2004, 02:08 PM
Thanks for the replys. I did some measureing and the vans glass is much taller then the trucks. I guess I will have to start searching the junkyards.
Old 04-29-2004, 06:37 PM
zieg96 zieg96 is offline
zieg96 is starting off with a positive reputation.
<!nate o23--I have the door glass and aillights real cheap. I am in NW IndianaE-mail me off forum if you are interested.>
Please do not try to sell parts on our boards, it is against our guidelines. You may use the classfieds section we provide
Old 04-29-2004, 09:59 PM
jamesgs47 jamesgs47 is offline
jamesgs47 is starting off with a positive reputation.
Be careful on the door glass. You have to use 87-96 or the window will not roll up and down. I found out the hard way that the 80-86 glass is about a 1/4" wider than the 87-96.
James
Old 04-29-2004, 10:02 PM
parks911's Avatar
parks911 parks911 is offline
parks911 is gaining momentum as a positive member of FTE.
Although alot of other body style years will fit your best bet will be used parts from the same body style. 87-91 F-series trucks will work perfectly.
You can also search salvage yards at www.car-parts.com
Old 04-29-2004, 11:06 PM
jamesgs47 I would agree on the window size but if you use the older wing window and track the 80-86 work fine.
Old 04-29-2004, 11:20 PM
Hugh1217 Hugh1217 is offline
Hugh1217 is starting off with a positive reputation.
<!I just took a 89 off the road and plan on parting it out,from Lake George in up state New York, Hugh>
Edited for same reason as above, FTE
Back glass interchange years? GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-24-2016 09:37 AM
Windshield and rear glass questions 81oneton400 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 06-15-2012 09:10 AM
Parts interchange 72F2504BY 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-12-2012 08:16 PM
4 door cab rear doors interchange MUSKRATT2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 12-12-2011 10:11 AM
Windshield Cross Reference Sniffels323 1968-2013 Full Size Vans 5 09-01-2009 09:53 AM
Tags
back, ford, glass, interchange, pickup, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
