1979 f250 16.5 x8 rims - Ford Truck Enthusiasts Forums
Old 04-29-2004, 10:38 AM
tomde2 tomde2 is offline
tomde2 is starting off with a positive reputation.
hello,
i need info. i have a 1979 f250 with 8 lug 16.5 x8rims on it. I want to go to 16" rims. I was told that i could use 8 liug rims from any ford 250 up to the year 1996.and also does anyone know for sure if the 16" rims will clear the brake caliper and any other factory suspention parts on the truck.
Thanks For the help,
tom
Old 04-29-2004, 11:06 AM
CO4x4SD's Avatar
CO4x4SD CO4x4SD is offline
CO4x4SD is starting off with a positive reputation.
I'm not sure of the backspacing but the previous owner had put on 305/75-16's on a 16" American Racing steel wheel. These are on my '79 F-250 and they seem to work fine. And yes, all 8 lug Ford wheels will fit your truck until the Super Duty years of '99 and up since they went to a 8x170mm pattern versus the old standard of 8x6.5
Old 04-29-2004, 03:10 PM
neverenough neverenough is offline
neverenough is starting off with a positive reputation.
You can use either the 80's-early 90's factory Ford 16"x6" or 16"x7". Direct bolt on with no issues. If you go aftermarket, make sure they are the correct back spacing, otherwise most any 16" aftermarket rim should work too.
Old 04-29-2004, 07:49 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
i've been told that ANY 8 lug rim from a light duty truck will interchange between brands. my 75 has the big dual piston calipers and they fit fine.
Old 04-29-2004, 10:40 PM
doc_f250's Avatar
doc_f250 doc_f250 is offline
doc_f250 is starting off with a positive reputation.
The Fords & older Dodges have larger hubs then GM, so keep that in mind when using stock rims....& the Super Duty's are metric, not the 8x6.5 pattern you have.
Doc
Old 04-30-2004, 06:10 AM
thanks for all the info guys i appreciate it.
tomde
Old 04-30-2004, 08:41 PM
cannonfodder's Avatar
cannonfodder cannonfodder is offline
cannonfodder is starting off with a positive reputation.
Question
And the correct back spacing would be? Moe
What rim fits a 1956 F250 truck dougert7 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 03-25-2015 12:33 AM
Need some tire and rim help 1979FordF-250Custom 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-09-2013 01:24 AM
Rim size Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-09-2007 03:13 PM
16.5 " rim fulltimehiboy 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-14-2007 08:12 AM
Is it possible to mount 16" tires on 16.5" rims w/8lugs??? lt dan 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-22-2001 09:05 AM
Tags
165, 165x8, 16s, 1979, 8x65, denver, f250, factory, ford, lug, rim, rims, swaput, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
