more power out of a 4.0 - Ford Truck Enthusiasts Forums
Old 04-28-2004, 01:56 PM
qwik88 qwik88 is offline
qwik88 is starting off with a positive reputation.
what can i do to get more power out of my 4.0 and what exaust sounds good on it thanks
Old 04-28-2004, 10:38 PM
ga302p ga302p is offline
ga302p is starting off with a positive reputation.
Computer Module like , superchips, hypertech, jet. On a small engine like that, probably flowmaster.
Old 05-01-2004, 04:37 PM
ejonn ejonn is offline
ejonn is starting off with a positive reputation.
Air Box
I put a fresh air filter system instead of the stock airbox and it made a HUGE difference. My 94 w/5 speed manual does not have any off the shelf chips available. If its a lower mileage engine.....SUPERCHARGE!!
Old 05-02-2004, 11:12 AM
94F150-408 94F150-408 is offline
94F150-408 is starting off with a positive reputation.
Exhaust system, look around for some equal length headers for it and a free flow catalytic converter, cold air intake or a K&N in the stock box and wrap the stock box and inlet tubes with thermal barrier. A complete tune up with quality parts including a new set of plug wires if old. Look at Diablo for a chip. Purchase a electric fan kit for your truck that lets you remove your stock, power robbing mechanical fan, this is a really good HP getter here. From there, you can have your cylinder heads ported and polished, look into a cam. See if anyone makes an aftermarket intake manifold? You could also go the route of a direct displacement supercharger on this engine, good for about 50% greater horsopower.
Old 05-02-2004, 10:09 PM
calgary_redneck calgary_redneck is offline
calgary_redneck is new and has a neutral reputation at this point.
The ohv 4.0 is always gonna run like a slug with anything short of a s/c on it and I don't know if i"d trust the bottem end for that
Old 05-02-2004, 11:20 PM
Quote:
Calgary, I'm not too familiar with how much HP a balanced 4.0 will support before having strength issues. All of the suggested upgrades would be what is nessasary to get rid of the "slugginess" you refer too. You would be amazed at the HP you can pull out a engine with all of the upgrades listed without the SuperCharger.
Old 05-02-2004, 11:57 PM
Quote:
Ya thats one I"d have to see to believe
Old 05-03-2004, 12:15 AM
What part of the upgrades are you uncertain about or doubting? Do you have personal experience on the listed upgrades not producing HP? Which of the listed upgrades have you performed to a 4.0? What makes you believe the bottom end is not strong enough for a SuperCharger? I'm very curious on your reasoning for this, these are all standard upgrades that have been done over and over on every size and kind of engine out there and they do work!
Please Explain!!
Old 05-03-2004, 12:24 AM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Copied from another of my posts with the same topic:
"I'd say just start with the basics.
1. Clean the mass airflow sensor. A little carb cleaner sprayed on the two wires cleans them off well.
2. New, good quality spark plugs. I prefer the Bosch platinums.
3. New O2 sensor.
4. Change trasmission fluid and filter. My filter was plugged with gunk / sludge / filings after about 40k miles. It ran much better after changing filter and fluid. I put in Type F for quicker shifts, and so far, 5k miles later, seems to be working great.
5. Run 35psi in the tires.
Now a little more involved.
1. K&N air filter. I hate to recommend them, since they let in a negligable amount more dust, but it did let my engine make more power.
2. Remove the muffler and exhaust resonator. That exhaust resonator after the muffler is very inefficient. It makes things quieter at the expense of performance. I just clamped a glasspack to the tube after the cat convertor, used the existing hanger, and stuck a turndown on the end of it. You can run a tailpipe if you wish. This probably helped more than anything I did before. I even picked up a little mileage. For even more performance, just run a pipe after the cat. It'll be quiet enough.
3. Remove and clean the upper / lower intake and the throttle body. If egr is used they can get quite dirty and block airflow.
Now quite involved:
1. Headers. Need I say more?
2. High flow cat converter.
3. Comp 49-410-8 cam. This should work with the stock computer.
4. Port the cylinder heads and port match / polish the intake.
Good luck!"
I can tell you, that my '92 explorer is NOT a slug. Not exceptionally fast, but good enough to scare some ricers and burn a good amount of rubber, and that's with 193,330 miles on the clock as of this afternoon. By the way, I have NOT performed every mod on the above list. Nothing in the "quite involved" category.
I do know why one would think that the 4.0 is a slug though. I have driven a '96 explorer with the 4.0L OHV engine. That thing WAS a slug. You could tell it was constricted even more than mine was before I started modifying it. The difference is in the cylinder heads. Starting in '94 or '95, they made the ports smaller to help light off the O2 sensor and heat up the cat convertor sooner. Goodbye performance.
Old 05-03-2004, 08:00 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
Hey dont go by what calgary redneck says hes definitely bowtie guy all the way. Running down fords at all opportunites. Think of this when he posts again.
Old 05-03-2004, 08:29 AM
Pretty funny he dident have any facts to back up the blather he posted about the 4.0, How bout it calgaryred? Its pretty funny that I asked him why basic engine upgrades that arent 'Brand specific" wont work and he has no answers as to that, just comments with no meaning...troll....
Old 05-03-2004, 08:42 AM
71FoMoCo's Avatar
71FoMoCo 71FoMoCo is offline
71FoMoCo is starting off with a positive reputation.
Quote:
Then "off with his head"!!
But seriously... I have a 94 with the 4.0 and 5 speed and I gotta tell ya, 1st and 2nd gears are pretty tough. Tough enough that the guys at the tire shop know me pretty well! I do think the 5 speed makes all the difference though, at least from what I've seen in driving a couple of automatics. Went head to head with a S-10 SS and stayed pretty even with him, and that's with him having a 35hp advantage on me, but his was an automatic. I think my 5 speed made up for the difference in hp.
Old 05-03-2004, 10:58 AM
Hey, mine's an automatic, and it does great.
2.3l to 4.0l SOHC - What would be involved? phoenix83 Ranger & B-Series 5 03-11-2010 02:57 PM
2.3 vs 4.0 mattri 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 8 04-12-2009 05:19 PM
more power for a 4.0 bigjohn1985 Ranger & B-Series 15 06-05-2007 07:41 PM
Whats the best chip for a 03 4.0ltr SOHC Ranger? WhyteRyda Computer Chips & Tuners 1 09-05-2005 09:22 AM
3.0 or the 4.0 chrowen 3.0L V6 4 08-27-2004 10:27 PM
Tags
1996, 40, 94, 96, building, engine, explorer, ford, hp, make, performance, power, preformance, ranger, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
