Another Truck Part 4
on
I took off the heads yesterday and had no luck getting it unstuck. The pistons ae clean and I can see a small line around each piston. I tried pulling the truck again. 4th and 3rd gear is just rolls and 1st and 2nd the rear wheels lock up. I broke the chain. I think I have to remove the crank and pound each piston individually. I'm gonna remove the tranny as well it so if it's okay. He tossed in a spare 4spd that he had. It's just been sitting in the back of the truck. It's completly dry and missing the shifter handle and E-brake handle. I think I might soak it and bolt on the missing pieces. See you guys later.
on
There is only one stuck piston. The 6th one is stuck good. The engine had been rebuilt by the looks of it and very little wear. You could almost eat off it! It's so clean. I have the engine on my stand with the crank removed. I have the cylinder full of WD-40. I really want to get it unstuck. I worked while it was rainning to get the engine out.
on
Oh I forgot to mention I found a dead mouse in the oil pan when I took it off yesterday. It must have crawled up the road draft tube and drowned in the oil. I've been wondering why the truck has always sat on angle. I was looking at the frame and noticed the passenger side spring has two broken leaves. Since I have a spare I'll change it while the engine is out of the truck. As I said a few minutes before. See you later guys.
MPH Racing
33
03-09-2008 08:10 AM
