Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-27-2004, 09:02 PM
skeleton33 skeleton33 is offline
Garage is empty, add now
skeleton33 is starting off with a positive reputation.
Cracks in Block
What's all involved in repairing typical cracks between the bolt holes and water holes and/or under the valves?
Thanks.
  #2 (permalink)
Old 04-28-2004, 01:08 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
If it's just the stud to stud crack you can just leave those alone. If you have cracks in the valves those will have to be drilled, screw it shut and grind it smooth. A professional should do that.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
