Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 04-27-2004, 11:48 AM
toolz_not_toyz toolz_not_toyz is offline
Garage is empty, add now
toolz_not_toyz is starting off with a positive reputation.
Virginia emissions and safety check
Whelp. I've run into a snag with the Prospect Truck posted in my gallery (a 1978 f150 4x4 with a 460 engine). I was under the impression that in Virginia you could get a waiver for the emissions test for vehicles over 25 years old. In closer inspection of the rules, it looks like that exemption is only available to vehicles with a GVRW of 10,000 pounds or more. Great. I don't think an f250 even has a rating that high! But then it gets worse.
In my previous state, Maryland, we didn't have visual safety inspections. Here in Virginia we do. And the rules for the safety inspection state the following:
1) Air pollution control system (1973 and Subsequent Models) must be installed and functional including the catalytic converter and restricted fuel tank filler pipe.
2) Floor pan must not have any holes which allow ehaust gases to enter occupant compartment.
3) Steering and inspection: must not have a broken frame.
So, I guess by the fact that the truck has a 460 engine with a dual exhaust pretty much means it won't pass emissions or safety (I didn't check for cats at the time and didn't even look at the engine yet since I didn't think emissions mattered, pretty big misinterpretation on my part). And I guess that hole in the floor pan that I was going to fix means I can't pass safety. And I guess that the plate on the cracked framed pretty much means the frame is cracked and the rules probably imply that you cannot fix a broken frame and expect to pass the safety inspection.
Gee whiz. Thought I had finally found The One.
Anyone here have experience with Virginia and these things?
  #2 (permalink)
Old 04-27-2004, 01:00 PM
Whoops. I think I misinterpreted the 25-year waiver. I think it means that vehicles 25 years or older and under 10,000 pounds are exempt. I guess vehicles that are over 10,000 pounds are always exempt.
So maybe I can sidestep emissions with the waiver and then sidestep the safety with Antique plates until I get this thing fixed up with emissions gear.
  #3 (permalink)
Old 04-28-2004, 01:54 AM
ashvalentine's Avatar
ashvalentine ashvalentine is offline
ashvalentine is starting off with a positive reputation.
A '78 federal 460 doesn't have an air pump so it has no cat. (A California 460 DOES.) You do have an EGR and stuff.
You'll still have to fix the floor pan and the steering bracket.
ash
['You'd want to do that anyways, right?']
__________________
1979 F-350 9200 GVW Supercab
351M/C6/Dana 70 3.73
Dark Metallic Brown & Pastel Sand
Looks like Dark Chestnut & Cream to me
  #4 (permalink)
Old 04-28-2004, 07:45 PM
ash
Awesome. Err, of course the 460 isn't original in this truck since its a 4x4. I just hope the engine is newer than the truck. Isn't that an emissions rule as well (that is, replacement engines have to be newer than the vehicle they go in)?
I hope to have a peak under the hood in a couple of days so I'll be able to see if at least some of the rest of the stuff is there.
You're right. I do want to fix that hole. It's pretty nasty. And the frame is actually welded with a plate and it's all still sound, it's just the plate is rectangular and welded continously on the left and right....so it will likely fail again. Replacing the plate with one that has tapered ends will be quite a job. But better safe than sorry.
Tags
inspection, safety, texas, visual
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
