Diagnostic Code Question
I have a 2000 Expedition and installed a low temp thermostat a couple of weeks ago. The other day the service engine light came on. I had the code checked an it was "P0125 -Insufficient Coolant Temperature To Enter Closed Loop" what does this mean how can I remedy it and is a result of me installing the low temp thermostat ?
Welcome to the forum.
Yes, but dropping the engine temp, it is not getting warm enough to run efficiently. The PCM doesn't go into closed loop until it reaches a predetermined temp.
Todays engines are designed to run at least 195 deg. to get propers ring seal and lower emmisions.
Put the stock 195 thermostat back in it. Your engine will last longer.
Jimmy
Jimmy
