Sealing carburetor base gasket? - Ford Truck Enthusiasts Forums
Old 04-26-2004, 09:09 PM
Polkat Polkat is offline
Polkat is starting off with a positive reputation.
My Motorcraft 2150 2bbl has a little nick in it's base plate. It can't be sanded without ruining the seal to the base plate gasket further. The carb is excellent otherwise, but sucks air loudly at the area where the nick is when running. Normally I would never seal a base plate gasket as most sealers, particularly silicon, will melt away in the presence of gasoline. But in this case, I'm wondering if there is some kind of sealer out there that will help with this? Any ideas? Thanks.
Old 04-26-2004, 11:42 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Maybe you can J-B Weld the chip then when it is set up, reinstall it and you should be fine.
Old 04-27-2004, 10:15 AM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
JB weld and a file.
O-ring? CB3 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-03-2016 07:12 PM
valve cover gaskets - Cork or Rubber best? kegger66 1973 - 1979 F-100 & Larger F-Series Trucks 22 07-01-2016 12:16 AM
302 rebuild Loctite/Anti-seize/ gasket sealer where? Redbeard55 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 07-27-2011 07:35 PM
Replacing rear main seal in 300. dani9678 Ford Inline Six, 200, 250, 4.9L / 300 6 03-11-2009 10:49 AM
Valley pan gasket sealer murdocksvillian 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 05-24-2006 09:36 PM
Tags
2150, bas, base, carb, carburator, carburetor, gasket, gaskets, jb, motorcraft, plate, seal, sealant, sealer, sealing, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
