302 Supercharger - Ford Truck Enthusiasts Forums
302 Supercharger
Old 04-26-2004, 04:19 PM
Sanders's Avatar
Sanders Sanders is offline
Sanders is starting off with a positive reputation.
302 Supercharger
In my quest for more horsepower I came across this supercharger. The description says it is for a 64-68 302 Mustang. Would this fit on any 302? I have a 1978 302 in a 1968 F100. Any input would be helpful, 2600 bones is a lot to spend on a part that might not fit.
Sanders
You requested a price quotation for: Paxton Novi 1200 Supercharger Kit for 1964-1968 Ford Mustang w/ Small Block (260-302 cid.) (passenger side mount - satin) [more info]
Part Number: PAX1001839
SuperchargersOnline.com*: $2,649.00
List Price: $3995
You Save: $1346
http://www.superchargersonline.com/p...ProductID=1181
Old 04-28-2004, 12:38 AM
Sanders's Avatar
I decided I'm going to order it. I called the tech line and they were not sure but they did admit that it was a 302 and it should fit. Also they said if it doesn't fit send it back and get a refund. I'll let yall know if it works.
Sanders
Old 04-28-2004, 07:21 AM
Scopie Scopie is offline
Scopie is starting off with a positive reputation.
as far as i know, with my limited knowledge on superchargers, centrifugal s/c's like your paxton are basically belt-driven turbos, with the lag eliminated via the direct belt drive system. the problem with centrifugal blowers on trucks is their power *starts* at about 3000 revs, vs. a positive displacement supercharger unit like an eaton twin screw, which starts from the moment you put your foot down. torque and power down low as well as up high from the twin screw positive displacement s/c's, instead of the high paxton/centrifugal 3000-5000rpm power band.
just my thoughts.
- Sean
Old 05-09-2004, 09:05 PM
DYERS6-71's Avatar
DYERS6-71 DYERS6-71 is offline
DYERS6-71 is starting off with a positive reputation.
is this a daily driver or for drag racing,etc...?
Old 05-09-2004, 10:59 PM
Sanders's Avatar
It is a daily driver so I might not get it. I need to punch the info into the destop dyno and see what I get.
Old 05-09-2004, 11:10 PM
Sanders's Avatar
I entered the data in the Desktop dyno and got some decent numbers. 500 ft/lbs @ 4000 rpm's and 524hp @ 6500. This is with the stock heads ported and large valves(2.1 and 1.6). 800 cfm carb and a 272 Energizer cam. These numbers are without an intercooler and running 8.5 to 1 compression.
347 stroker 550ft/lbs @ 3500 rpm's and 500 hp @ 5000 rpm's.
Interesting numbers but probably would not make a good daily driver. It would be fun though.
Sanders
Newbie 302 // Mustang II // Rear sump? tmcquick 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 10-19-2015 04:46 PM
302 question frankensteined_67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 08-29-2015 10:05 PM
idea for an efi 300 six cyl supercharger.. 70torino429 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 11 07-13-2015 07:35 PM
Anybody got a 2.3L Whipple on their Lightning or Harley Davidson F-150? Super Duty DJ Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 08-07-2014 10:18 AM
289 to EFI from 5.0 Mustang Engine craigibc Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 08-15-2010 11:14 PM
Tags
302, carb, carburated, carburetor, centrifugal, eaton, fit, ford, make, paxton, stroker, supercharged, supercharger, superchargers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
