Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-18-2002, 04:22 PM
larbuck larbuck is offline
Garage is empty, add now
larbuck is starting off with a positive reputation.
biodiesel ?????
has any one ever heard of this stuff if you go to www.greasel.com it has a PSD running on it i was fust courious if any one has ever did this conversion and how did it work
If you want to run your diesel engine on alternative fuel, and want a simple alternative to Biodiesel, The Greasel conversion kit is for you.
The Greasel conversion kit is a ready-to-install kit that will allow you to run any diesel on free waste vegetable oil. The key to running a diesel on vegetable oil is heat. This is done by a special tank and fuel line, heated with the hot coolant your engine is already producing. The engine is started and brought up to temperature on regular diesel. When the engine and tank of vegetable oil is warm you simply flip a switch on your dashboard. The fuel solenoid switches you from diesel to vegetable oil and suddenly you're going down the road for free! Furthermore, there is no power loss, a cleaner exhaust, and a better lubricated engine! About 5 minutes before you get to your destination, switch back to diesel to clear the injection pump and fuel lines of vegetable oil.
__________________
Louis
1975 highboy work in progress
  #2 (permalink)
Old 08-18-2002, 06:04 PM
The Diesel Dude The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
biodiesel ?????
Does your exhaust smell like french fries?
  #3 (permalink)
Old 08-18-2002, 08:54 PM
craterjoe craterjoe is offline
craterjoe is starting off with a positive reputation.
biodiesel ?????
there is a big push up her in minnesota for biodiesel but rather than vegi oil it is more specifically soybean oil and I have heard reports that state that it doesnt take any special hardware and works just the same as regular fuel. And I can state from personal experience that it does remind you of going by a fast food restaraunt. My former employer was involved in the testing of the stuff when they were first getting the bugs worked out and I didn't notice any difference except for the french fry cravings.
b.T.W. The Diesel Dude I filled the fuel tank on the f250 today and the idle surge stopped. there must be an air suck in the fuel tank
Craterjoe
__________________
Craterjoe
1996 Bronco XL 5.0 E4OD
No Matter Where You Go There You Are ... Buckaroo Banzai
  #4 (permalink)
Old 08-19-2002, 01:26 AM
Saigon's Avatar
Saigon Saigon is offline
Saigon is starting off with a positive reputation.
biodiesel ?????
Hi,
Where I live , Chateauroux- France, all the local buses run on colza oil. No special mods on the engines except some additives in the winter to avoid congealing. I havent tried it in my truck yet since we cant find it at the pumps in town but we should have it in 2003.
Magic
__________________
1986 7.3l (1989 engine) 4x4 , used to be 6.9 ! Alloy rims, dome lights,
manual switch,Bosch GP's, veggie setup for WVO
  #5 (permalink)
Old 08-19-2002, 11:22 AM
curmudgeon curmudgeon is offline
curmudgeon is starting off with a positive reputation.
Post biodiesel ?????
Two of the unresolved issues with biofuels are increased corrosion and wear of injection system components, and some of the polymers and elastomers used in fuel systems are incompatible, i.e. they either swell, harden, or break down. No bolt-on "system" for the use of biofuels addresses these rather serious problems. The only successful long-term biofuel conversions I know of involved changing every seal and o-ring in the system to special resistant materials. The "Greasel" system you describe might work well in mild climates on an older IDI engine with plenty of additives. How far would you have to drive to re-melt an entire tank of gelled fuel in freezing weather? I hope somebody is working on these problems - I've been waiting for this for years.
  #6 (permalink)
Old 08-19-2002, 06:00 PM
ybiofuels ybiofuels is offline
ybiofuels is starting off with a positive reputation.
biodiesel ?????
[updated:LAST EDITED ON 19-Aug-02 AT 07:03 PM (EST)]Well, it seems like there is some misinformation out there with regards to biodiesel.
Corrosion is not a problem! Biodiesel has a higher lubricity than petro diesel and actually extends engine life.
Gelling is not a problem unless you are in a climate where below 25 F is common, in which case anti-gels work just fine, or you can mix with petro diesel.
It seems people are confusing biodiesel with vegetable oil. Vegetable oil use in engines has some major problems- the type you've discussed. Biodiesel is not vegetable oil. It has been chemically thinned so that it is almost exactly the same as diesel fuel in nearly every category. I have been using it for quite some time in my 1984 mercedes station wagon as well as my 1990 7.3 liter F250, and it does just fine. Yes, it wears down rubber parts a bit faster than petro-diesel, but that just means that when i notice degradation (nothing ever breaks or bursts in mine or any other local biodieselers' experience), i replace with synthetics, i.e. silicone, teflon, viton, etc. Biodiesel REQUIRES NO CONVERSION (the greasel kit is for using straight vegetable oil- not biodiesel) and can be mixed with diesel in any amount. It is actually good for your engine- its solvent nature and high lubricity keep the fuel system clean and the engine running smooth. It also has a high cetane value and way less emissions. e-mail ybiofuels@sbcglobal.net for more info.
thanks.
  #7 (permalink)
Old 08-20-2002, 11:32 PM
FordRancher's Avatar
FordRancher FordRancher is offline
FordRancher is starting off with a positive reputation.
biodiesel ?????
The biodiesel that is becoming available on the market is a blend with regular diesel. The article I read about it said it is most commonly used as 2% biodiesel with reg. diesel, but is is also available as 5% and 20%, but the costs are to high at those blends to justify it. From what I understand though, it isn't available at the station pumps yet, maybe that was just for the region. This was a farm publication and they said it was being delivered to some farmers and small fleet trucks were using it, such as postal carriers. They were claiming that a 1% mixture of biodiesel is 65% more lubrication than normal diesel. They did warn that it is a strong solvent and if you get any on your paint you need to wipe it off right away or it will eat the paint. The farmers they intereviewed claimed they couldn't see a power difference or economy difference, but that their older tractors did not smoke as much. The experts claim a slight reduction in power and economy however.
I hope this adds to somebody's knowledge and that I can learn more. I like the sounds of biodiesel from what I've read, but I'm kinda skeptic because of the claims of ethanol also and I know of some problems with it and wouldn't run it. Later
__________________
D.D.T.
2002 F-250, SC, SB, 4x4, V10, 6spd, 4.30 LS, Chrome Tubular Steps, Toredoar Red, Mr. Pick-up Chrome grille guard.
  #8 (permalink)
Old 08-22-2002, 08:47 PM
z1express z1express is offline
z1express is starting off with a positive reputation.
biodiesel ?????
I live in southeastern Michigan an have run the BioDiesel in my 2000 stroker. The blend I used was 20%, and it was 15cents a gallon more tha regular diesel. I felt in my truck that power increased slightly (maybee it was the fresh wash job) And the engine ran smoother and quieter. The fuel mileage stayed the same at 18.6 mpg,as I run typically the same 500 miles a week. I was out back sniffing the exhaust and did not smell any french fry odors. Seems like a good product but to expensive.
__________________
00 CC 4x2 SB 3.73,Century matched cap,Aero mirrors,SuperChips Microtuner on 60 H.P. LF-777 bypass oil filter,switch on backpressure valve,XLT-250 SD 7.3 Auto, Delvac oil 15k oil changes
  #9 (permalink)
Old 09-06-2002, 06:55 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
biodiesel ?????
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #10 (permalink)
Old 09-07-2002, 06:34 AM
mtnbikerman mtnbikerman is offline
mtnbikerman is starting off with a positive reputation.
biodiesel ?????
I live to far from it But as soon as I get my Excursion and the warranty runs out I will be buying it and having it shipped to me does anybody know what Fords stance is on Biodiesel?
Thanks
  #11 (permalink)
Old 09-07-2002, 11:19 AM
hitecdan's Avatar
hitecdan hitecdan is offline
hitecdan is starting off with a positive reputation.
biodiesel ?????
I read somewhere that their were some compatibility issues with biodiesels and some engine designs, mainly the injectors. Some diesel engines can run biodiesel okay, while others will need some major mods or won't run the stuff at all. Not sure which category Ford's PSD fits into.
__________________
2003 F-350 Lariat CC/6.0L /TorqShift/FX4/SRW
http://dan.prxy.org
Born on date: Jan 20, 2003
Number of reflashes done: 2 (05E15 Jan 8, 2007)
Number of C94 injectors replaced: 0
Number of times the EGR valve has been replaced/cleaned: 0
  #12 (permalink)
Old 09-07-2002, 03:56 PM
biodiesel ?????
It seems to me like I heard that the newer model diesels would work on biodiesel and the manufacturers would cover the warranty. But I don't remember for sure and if it was all U.S. manufacturers or just some of them. I don't know if 100% would work though because it is such a stout solvent it'd probably eat through seals rather quick. That is why the didn't recommend it for older models is because the seals aren't as tight on the fuel system or something like that. I guess I need to do some more checking. I'm kind of interested in it but it sounds like the price will probably be going up since the grain markets have been up all week, but I'm not sure what the soybean market has been up. Later.
__________________
D.D.T.
  #13 (permalink)
Old 10-11-2005, 03:58 PM
ymmv ymmv is offline
ymmv is starting off with a positive reputation.
I don't know that I like the complications of running cooking oil, but you've got to appreciate the photo they put together for their Web site. www.greasel.com
Tags
250, bio, conversion, fuel, kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
