explorer towing capacity - Ford Truck Enthusiasts Forums
Old 04-24-2004, 05:38 PM
schalfmile schalfmile is offline
schalfmile is starting off with a positive reputation.
I have a 2002 explorer 2wd with a 4.0v-6 and the towing package.....Do you think i could safely tow approx 5500-6000 lbs?
Old 04-24-2004, 06:00 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
No. Chances are the trailer you are towing is too long for an Explorer and you will have a problem keeping that much weight under control with an Explorer. Regardless of Ford's max towing limit, that is more than most people would attempt with an Explorer. Most serious RV people recommend a 3/4 ton truck for anything over 5K, and the Explorer is not even in the 1/2 ton class.
Old 04-24-2004, 08:22 PM
dougandrochelle dougandrochelle is offline
dougandrochelle is starting off with a positive reputation.
I agree, that would be A LOT of weight for your Explorer, don't know what your GVWR is, but I would fall off my chair if it were anywhere near that. 6k with an Explorer, you would be straining the whole powertrain. Plus, with that shortwheelbase I imagine you will be all over the road...
Old 04-26-2004, 11:03 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Look at your owners manual. I think 5000 is the absolute maximum. 4000 would be closer to a sane limit, except for short local tows.
Jim
Old 04-26-2004, 08:02 PM
penguin149 penguin149 is offline
penguin149 is starting off with a positive reputation.
I had a '96 Explorer 5.0L V8 and towed a 24ft 4500# TT for a few months. The tail wagged the dog! Being passed on the interstate meant a white-knuckled ride. The power was fine with the V8 but too short of a wheelbase made for miserable trips. After a close call, I traded for a F150 4.6L V8 and never looked back. MAYBE if I had bought a Hensley hitch I would have been OK, but I still felt better with the 150. Now I tow a 30ft 7100# TT with a F25 V10. Personally, I wouldn't try to tow 5500#+ with the V8 Explorer and certainly not the V6.
Jim
Old 05-19-2004, 11:43 AM
jddaero jddaero is offline
jddaero is starting off with a positive reputation.
I have a '94 explorer and can't pull a 6x10 utility trailer with 2 motorcycles on it without the check engine light coming on. It has done it 2 times. The first time I only had one bike on it. According to the manual it is rated for 5280 lbs and you have to subtract the weight of the truck 4150 lbs and its contents (passengers). That does not leave much weight to tow. Love the truck but it sucks at towing!
Old 05-19-2004, 03:03 PM
Jbsqared Jbsqared is offline
Jbsqared is starting off with a positive reputation.
First, the new 4.0 SOHC motors, are good for towing, but not for that much weight. They are A LOT better than the older 4.0 engines. I tow a trailer with my 97 Explorer with the SOHC motor. The trailer weighs about 3300 lbs with water, propane, etc. I can pull up most hills fairly easily, but in the mountains where I live, its a little harder. 4000 lbs is the most I recommend pulling with your Explorer.
Old 05-19-2004, 03:23 PM
only towing about 2K
I am only towing about 2000 lbs. Small trailer and two bikes. Does this mean I have a problem with my trans? It pulls good, but the trans overheats. This happens on flat land driving to the beach.
Joe
2004 Explorer 4x4 Flat towing RN RV'R Explorer, Sport Trac, Mountaineer & Aviator 3 05-22-2011 10:01 AM
2003 explorer towing question rlr7239 Explorer, Sport Trac, Mountaineer & Aviator 4 02-23-2010 03:47 PM
Trailer Tow Wiring - 96 Explorer texan2004 Explorer, Sport Trac, Mountaineer & Aviator 12 07-19-2009 10:25 AM
Will the explorer tow out trailer? Frdbuy8589 Explorer, Sport Trac, Mountaineer & Aviator 6 09-08-2006 01:19 PM
How well does your explorer pull a camper toddn78 Explorer, Sport Trac, Mountaineer & Aviator 8 02-20-2006 05:59 AM
Tags
07, 1997, 2002, 40, 50, 50l, capacity, explorer, max, mountaineer, pulling, rating, tow, towing, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
