rear end in an 84 f150 300i6 automatic c6?
I'd guess a 9" offhand. Does it have a removable carrier - bolted on from the front of the axle housing?(9") Or, does it have an access panel that bolts on the rear of the housing? (8.8)
If you're wondering about gear ratio you have, there should be a metal tag under one of the mounting nuts - usually first three numbers on the bottom line of the tag.
84f150guy
123
10-15-2011 05:47 PM
1977ford05
05-25-2008 09:34 AM
Windsor84
06-11-2006 12:29 AM
84f150guy
04-14-2003 02:59 PM
