Changing oil in 7.3 93 F250 diesel - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-01-2002, 09:16 PM
EaSTxCOwboY EaSTxCOwboY is offline
EaSTxCOwboY is starting off with a positive reputation.
aight. im new to diesels. how many quarts of oil? what type? and how many thousand miles should i change it. thankz
Old 05-01-2002, 11:51 PM
babbler babbler is offline
babbler is starting off with a positive reputation.
My 90' 7.3 holds two and a half gallons so i usually buy 3 one gallon jugs of rotella and just check as i add it,And as far as milage goes if you do alot of pulling or working the motor i would change it at 3,000 or if you not working too hard you can go 5,000 miles but check it when you every other or even every fill up is what i do.hope this helps you out.
Old 05-02-2002, 12:01 AM
Rockingrodney Rockingrodney is offline
Rockingrodney is starting off with a positive reputation.
I use my truck mainly as a highway truck, "HONEY WAGON" and every once in a while I pull a boat. Everyone around here says change every 6000-10000 miles, do yall think it will hurt to go that long or what?
2001 4*4 short bed crew cab PSD
Thanks
Rodney
Old 05-02-2002, 01:15 AM
stroker_1 stroker_1 is offline
stroker_1 is starting off with a positive reputation.
I have a 97 f250 PSD and it takes 14 quarts with a filter change. I personally believe in and use BP Vanellus C-Extra 15-40. I buy it in gallons for about $22.00 per case(4 gals) at my local BP bulk plant. If you run your diesel hard, drive in dusty areas, or tow you should change it every 3000 miles. If not every 5000.
Old 05-02-2002, 04:50 AM
Roaring Roaring is offline
Roaring is starting off with a positive reputation.
Hi there ..
I have changed oil every 6000 miles in my 93 since new and have about
163000 miles on the engine with no troubles at all...
I live in Canada and use a 15 40 weight in the summer and a 10 30 in the winter look in the owners manual or on the oil cap for the proper grade of oil.. it takes about 10 quarts with a filter change... good luck I know you will enjoy the truck
Old 05-17-2002, 08:46 PM
bisaksen bisaksen is offline
bisaksen is starting off with a positive reputation.
Is it true that it is normal for the Powerstroke diesel to burn 2 qts of oil between 5,000 mile oil changes?
I am looking at buying a 1996 F350 that was used as a work truck. The owner says the 2 qt burn is normal.
Old 05-18-2002, 02:18 AM
rotorhead rotorhead is offline
rotorhead is starting off with a positive reputation.
What's "normal" oil usage seems to be an individual thing. I've seen and heard lots of folks claim that their PSD will be a quart or so down between changes. Mine is a 97 and (knocking on wood as I type, which is not easy!!) doesn't use any...at least not any measurable amount. If a good thorough look-over and crawl-under doesn't reveal any oil leaks, and if you're not smoking A LOT (a diesel's gonna smoke sometimes, particularly at start-up) then a quart between oil changes wouldn't worry me. 2 quarts probably wouldn't overly concern me either. I'd say that over all, a bit of usage between changes is probably "normal".
Old 05-18-2002, 08:37 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
I change the oil on my truck every 4000 miles, and I find that I'm about 1 quart low at about 2600, so I add one, and at 4000 I'm 1/2 quart low again, so I guess I'm burning 1 1/2 qts in 4000 miles. I don't leak or smoke excessively, and the truck runs great, so I'm not concerned, and I'm not even thinking about investigating any further.
On a similar note, I've been told that a small block Chevy might burn as much as 1 qt every 600-1000 miles, and that's within the range of acceptability!! Acceptable to some maybe.
Just my $.02.
Old 05-18-2002, 10:31 PM
newtruck newtruck is offline
newtruck is starting off with a positive reputation.
I changed oil, 15 qts, and filter at 2,000 5,000, 10,000 & 15,000. Only 17,000 miles on it now. It uses 1 qt between changes, except for the first change. When I start to tow my travel trailer all the time I will chage oil sooner depending on how hard I work the engine....Richard
My ride is a 2000 F350 Super Duty, Lariat, PSD, 4X4, long bed, 4.1 rear, automatic, SRW, with added stainless steel 4" exhaust, turbo to 5" tip, with a "see thru" muffler and EGT, Trans temperature with turbo psi gauge. I tow a 12,000 pound 28.6 ft travel trailer
Old 05-18-2002, 11:34 PM
Thanks for the feedback, I am not worried now. By the way, this guy is a contractor/friend of mine and I didn't really have any reason not to believe him, esp because he has 3 diesel Ford pick ups and they all burn oil between changes. He even told me to stay away from any diesel that doesn't burn a little oil because that could indicate a problem. I will probably drive the truck on Monday. It is a 1996 F350 w/ 117,000 miles on and everything appears solid and the original box was just put back on, so it looks great. Biggest concern now is how to address ride quality as he had the stock F350 suspension upgraded to an even heavier rating.
Old 09-09-2002, 04:10 PM
mike83 mike83 is offline
mike83 is starting off with a positive reputation.
my 95 7.3 takes 15 quarts i also use rotella
Old 09-10-2002, 06:37 AM
91F250DSL 91F250DSL is offline
91F250DSL is starting off with a positive reputation.
[updated:LAST EDITED ON 10-Sep-02 AT 06:38 AM (EST)]Well I just did my first oil change on my latest acquisition (91 F250 DSl 7.3L engine) and I did notice the guy at the place that did all fluid changes for me (first diesel for me I wanted to make sure things gets checked properly) when he changed the oil filter, he filled it to ensure no air was in the filter before replacing it back unto the engine, after asking why he was doing that, he answered that sometimes the vacuum of the diesel can crush (implode) an oil filter.
He also reccommend the 15w40 rottela oil to be changed every 5K miles.
something to think about.
91 ford F250 Super Cab, 300K miles on it, hauls 2 horse trailer + horses without any issues. Gotta love them bad *** diesels.
Old 09-10-2002, 10:37 AM
dale i dale i is offline
dale i is starting off with a positive reputation.
Old 12-06-2008, 11:45 AM
2002ExcursionV10 2002ExcursionV10 is offline
2002ExcursionV10 is starting off with a positive reputation.
hey mike83, I just bought a 1995 7.3 PSD, I love it so far. How often do you need to change your glow plugs/glowplug relays? I drive mine maybe a few days a week (not often) and it has 211k miles. With this many miles, do I have to start worrying about major repairs or not? I know the 7.3 PSD is a greqat engine so I don't think I have to worry, but I would still like your opinion. Also, (not including fuel) I don't mean to get nosy, but what are your average monthly running costs (as far as regular maintenanace goes)? Thanks, Nick.
Old 12-06-2008, 11:56 AM
GEugeneS GEugeneS is offline
GEugeneS is starting off with a positive reputation.
Quote:
I heard it's just better to put oil in the filter because it's so big and when you first start the engine after the change, the filter has to fill up before you start getting oil pressure to the engine.
oil change 7.3 diesel charlie555 1999 - 2003 7.3L Power Stroke Diesel 20 06-22-2015 10:25 PM
fuel filters? bobkonaben 1999 to 2016 Super Duty 1 04-11-2015 06:43 PM
Why add 2 cycle oil to diesel fuel? rackhound 1999 - 2003 7.3L Power Stroke Diesel 65 06-09-2013 11:58 PM
Synthetic / Synthetic Blend Oil ????? sledhead999 1999 - 2003 7.3L Power Stroke Diesel 4 12-05-2002 06:47 PM
7.3 diesel normal oil consumption. wgw 1999 - 2003 7.3L Power Stroke Diesel 20 09-13-2002 09:05 PM
Tags
1996, 73, 73l, change, diesel, duty, f250, f350, mile, motor, need, oil, quarts, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
