Changing oil in 7.3 93 F250 diesel
Old 12-06-2008, 11:05 AM
sneak's Avatar
sneak
sneak is offline
I just changed oil last night on my 02 F-350. I changed the full flow oil filter, the bypass oil filter, drained the HPO rezevior, drained the pan, installed a fumoto drain valve, and refilled with scheaffers 9000 for the first time. I put on about 18 quarts and need to double check the oil level.
Old 12-06-2008, 11:08 AM
GEugeneS's Avatar
GEugeneS
GEugeneS is offline
Oh Yeah, the original question: Mine takes 15 with a new filter (which is always). I only put about 2500 miles a year on the truck now since fuel went up and my earnings went down so I change once a year. But the cars I change at 5,000 since 1. 5,000 is an easy number to remember, and 2. I read an oil report several years ago that said they couldn't tell the difference in engine wear at 100,000 miles until oil changes exceeded 7,500 miles.
Old 12-11-2008, 01:45 PM
rigoberto's Avatar
rigoberto
rigoberto is offline
95 dump uses too much oil
Hi everyone I own a 95 superduty 7.3 turbo it uses about a gallon of oil every 40 miles, I have no leaks, i was told that the problem was the head valve seals, i replaced them but still uses the same amounth, any clues thanks
charlie555
20
06-22-2015 09:25 PM
bobkonaben
1999 to 2016 Super Duty
04-11-2015 05:43 PM
rackhound
65
06-09-2013 10:58 PM
sledhead999
12-05-2002 05:47 PM
wgw
20
09-13-2002 08:05 PM
Quick Reply: Changing oil in 7.3 93 F250 diesel
