Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-23-2004, 11:56 PM
ruttrowe ruttrowe is offline
Garage is empty, add now
ruttrowe is starting off with a positive reputation.
propane conversion?
Anybody try this yet? I heard it burns cleaners and can be switched from diesel to propane on the fly. supposed to be more economical. please advise.
rutt
  #2 (permalink)
Old 04-24-2004, 12:03 AM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Your looking into big time mods to do this, changing injectors and other various parts. Unless you are made of money or racing I would really do some research first.
Fire Rooster
__________________
2012 F150 Screw, 2x4 XLT+, Bad Boy Black[SIGPIC]
2002 F250 CC,SB,4X4,Lariat...SOLD. 2003 X, limited SOLD
  #3 (permalink)
Old 04-24-2004, 08:21 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
You might be referring to propane injection rather than a propane conversion. I've got propane injection on my truck, where the propane is injected into the airflow pre-turbo, and improves the efficiency of the diesel burn, plus adds power. Used sparingly, it can/will improve mpg, but I keep mine wicked up for additional power. I still get the same/better mpg than before, but I get there much sooner.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #4 (permalink)
Old 05-09-2004, 06:26 PM
rickbow rickbow is offline
rickbow is starting off with a positive reputation.
Quadzilla,
Could you tell me more about your propane injection system? What is the best system? What better fuel mileage did you get before/after? Cost vs. fuel mileage?
Much thanks.
Rickbow
__________________
2004 Excursion LTD 6.0 PSD, Pueblo Gold, Oil Guard Bypass Filter, Banks Six-Gun (on order), Hadley Bully Air Horn, Brown Bread Sound Insulation
  #5 (permalink)
Old 05-09-2004, 09:19 PM
BigBully BigBully is offline
BigBully is starting off with a positive reputation.
I have to say Most Guys DID Not do propane to get better Mileage, They do it for ALot more Power. Even if it does give some extra MPG its offset by Haveing to Buy Propane. IMHO the Powershot2000 Is the best system. It dont need Mixers and heaters To make it work, It is Just Vapor and Works real well. The way I have mine set I get about 85 Extra HP To the rear Wheels.
__________________
79 F150 4x4 500+ci
79 F350 4X4 5.9 Cummins Twin Turbo
97 F350 4x4 CR Cummins Twin Turbo
  #6 (permalink)
Old 05-09-2004, 10:53 PM
I started thinking about doing this, but after posting this, just reconsidered, after looking at another post where a guy just added a modified exhaust and chip and blew out his engine. Ford said they would not warranty the engine. Going to cost him $13,000 to replace. I was trying to find more ways to increase fuel efficiency- with the increases of gasoline prices these days- but as you said, it's bascially offset. Being a new truck, I think I'm pretty much stuck with the way things are until my warranty runs out. Thanks for the reply Big Bully and GOOD LUCK! (I may reconsider down- the- road.)
__________________
  #7 (permalink)
Old 05-09-2004, 11:39 PM
Frost13's Avatar
Frost13 Frost13 is offline
Frost13 is starting off with a positive reputation.
If you want better mileage and do not want to void your warranty, get a free-flow tailgate or a camper shell or a tonnaeu(whatever) cover. Also if your engine has been taken care of, and you do not think it will have problems(before warranty is over), get you a Tymar air filter and a 4inch exhaust.
If you want even better mileage and sound, take off the muffler and the cat. Sounds great! But i think that the exhaust and air filter will void your warranty, so only put those on if you are COMPLETELY sure it is what you want to do.
__________________
I BLEED SOONER RED! GO SOONERS!
1994 F-150 S/C S/B 2wd XL, 300, 5-speed, 3.55, 183k
  #8 (permalink)
Old 05-10-2004, 07:22 AM
Fordafied's Avatar
Fordafied Fordafied is offline
Fordafied is starting off with a positive reputation.
Not to hi-jack this post but, Will a Tymar and 4" exhaust void your warranty??? I am having both of them delivered as I type. Mine is a 2000 so the warranty will be running out in 10 months anyway.
__________________
2000 F-250 PSD CC 4x4 auto, Propane injected, 6- pos chip w/TWildman tunes, BTS valve body, Auto Meters, 4" turbo back exhaust, Tymar intake, , Wicked Wheel, Overboost eliminator, CCV + more
  #9 (permalink)
Old 05-11-2004, 06:53 PM
JMorton JMorton is offline
JMorton is starting off with a positive reputation.
Tymar and Exhaust will NOT void the factory warranty. I do warranty repairs on trucks with intakes and exhaust systems everyday. Don't sweat it with those parts.
__________________
97 Crewcab PSD, Wildman chip, DIY-injectors stage 1's, SD Intercooler, 3" DP, 4" straight pipe, DIY exhaust brake, Tymar, Shimmed FPR, Bully Dog propane, Diesel Turbo Lifesaver, Autometer Gauges, B&W hitch, Timbren SES.
Tags
2000, 60, conversion, diesel, diy, economical, f150, f250, f350, ford, lpg, onversion, propane, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
