Removing steering box! Help
I am doing a frame up restore on a 57 f100. This is my first rebuild so I am not very smart yet. I need help disconnecting the steering box from the frame so I can remove the cab. I am having the frame powder coated so I all has to come off. Any info will be very helpful considering right now I know nothing. Please try to use simple terms Or you will loose me. I would also like to say THanks to everyone who uses this sight I have used it soooooo much to get me this far. you guys are great.
Thank you
Ryan (1st timer)
Thank you
Ryan (1st timer)
on
This is assuming you partially dissasembled the front end. I did this on a '51 but it's the same principle. You can get a pitarm puller. I got mine off with a small gear puller that I could just get the arms behind the pitarm. You will need a steering wheel puller to remove the steering wheel. Unbolt every thing that attaches to the column in the cab and remove the floor cover. There should be a couple bolts that hold the box to the frame. Undo those and it should pull right into the cab or if the engine is removed right out the bottom.
steering box
the truck is completly apart. There is the shaft that runs through the frame. I unbolted four bolts so I can see the gears and the shaft but it won't slide out. Why do I have to take the steering wheel and colum out now. Is this required to just unbolt box from frame. My goal right now is to remove all parts so I have just a frame.
ryan
ryan
Short answer is "Yes". The box is bolted to the frame from the outside, that's why the pitman arm has to come off. The steering shaft runs all the way up to the wheel as one long piece, no rag joint or coupling.That is why the wheel and column come with it. You can get it out with the wheel on if the seat is out of the way, but it's way easier to pull the wheel. The column has a clamp where it attaches to the box so you can slide the column off the shaft after getting it out of the truck. If you can see the gear you have removed the cover, not the bolts that hold the box to the frame. A shop manual would be a very good investment and can be had from this site and many other vendors. Good luck with the truck.
Bob
Bob
The shaft comming out of the steering box is called the sector shaft. The sector shaft has a strait spline or gear like teeth on it 3 or 4 just on the bottom side. If you have it moving it is almost off. It should pull strait off if you tap it in and then try to pull off may help. Also if you try pull it off with a screw driver driven in the slot it should come off.
Enjoy the experience and learn as much as you can. I bought a 48 F1 this past winter and have spent couple of months tinkering and fixing things. This is my first time doing any thing like this. Having a blast. Most of the folks on this forum have been through
this and are willing to share their expertice.
Terry
Terry
Originally Posted by Sixoh
Whatever you do, don't get discouraged!!! Hey, I just sent you an email....
Shane
Shane
