exh brake do it yourself
Here you go. Scroll on down. The diesel stop also has this article with a diagram, but I've been unable to get the link to work.
http://pages.prodigy.net/stevebaz/_i...az/index3.html
If you go to ford-trucks.com, send SellwithSam a message, he has the diagrams to do it. If I were to do it again, I'd leave out the always on side of the switch and just use a single position switch wired into the ivs with a relay, that way you can switch it on and it engages as soon as you let of the throttle, disengages when the throttle is applied. For the money you can't beat it.
