Diesel Lifespan? - Ford Truck Enthusiasts Forums
Diesel Lifespan?
Old 08-30-2002, 08:51 AM
dale i dale i is offline
dale i is starting off with a positive reputation.
Diesel Lifespan?
Old 09-04-2002, 12:11 AM
Berserk Berserk is offline
Berserk is starting off with a positive reputation.
Diesel Lifespan?
I'm always looking to get back into an F-series again and I was wondering what a reasonable lifespan would be for a stock, well-maintained 6.9L. Any descriptions of what to look for when checking out a truck would be appreciated as well.
Old 09-05-2002, 06:13 PM
Diesel Lifespan?
No one has any idea how long I could expect a late 80s, early 90s 'Ford diesel' to last?
Old 09-06-2002, 12:25 AM
Brian460 Brian460 is offline
Brian460 is starting off with a positive reputation.
Diesel Lifespan?
I would say it is pretty much a guess. My dad bought his new in 85 it blew up after 130K he was very good at keeping the maintence up on it. I had a friend that had a 84 and they got 350K out of theres before it went.
Old 09-06-2002, 06:10 PM
theologian's Avatar
theologian theologian is offline
theologian has a good reputation on FTE.theologian has a good reputation on FTE.theologian has a good reputation on FTE.
Diesel Lifespan?
If a diesel is properly maintained, instead of just changing the oil when it gets thin, it is possible to get many hundreds of thousands of miles out of it. However, not babying the engine, and keeping levels constant and fresh will cause excessive wear on the engine, and significantly shorten it's life.
The powerstroke could be expected to run for 400K miles, if treated well. There are plenty out there that did not get much past the 200K mark,because of lack of proper maintenance. I had an old perkins engined truck with 500K on it, when I sold it - still running strong.
Wm
'02 F250 4x4 Crew Cab Lariot; white with leather - 3.73 gears. Not yet modified but the accessories are looking good.
'96 F450 4x4 Crew Cab XLT; White with Grey interior. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb, 4.10 gears, 12,ooo# winch
Old 09-07-2002, 09:36 PM
crash71us crash71us is offline
crash71us is starting off with a positive reputation.
Diesel Lifespan?
i have two 1986 F250s with 6.9s. one is 4x4 with 200,000 and one 4x2 with 450,000. both just had head gaskets changed for preventive maintance and water pumps and are still giong strong.the 4x2 is my daily runer and my trip truck is goon 700 mile round trips all the time. good luck
Old 09-08-2002, 05:34 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
wolfmanagh is starting off with a positive reputation.
Diesel Lifespan?
we sent a 6.9 to the bone yard with only 240,000 on it. Not because of the motor. We sent it down cause we lost another tranny and the van had a realy bad case of ford cancer on the body. (some nice holes in the floor were good for fresh air) Anyways we took of the one good head and injector pump for spare parts for another 6.9 we still have.
Old 09-22-2002, 10:37 AM
texlex texlex is offline
texlex is starting off with a positive reputation.
Diesel Lifespan?
i have an 84 ford f250 6.9. i have about 530k on right now. i use about 2 qts of oil per 3000 miles. the only thing that has been done on it is new crank shaft rods mains oil pump and head. it is still running good. i have a small rear main oil leak but thats it
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
1997, 2001, 60, 73, average, diesel, engine, f250, ford, life, lifespan, powerstroke, span, transmission, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
