7.3 Diesel Longevity?
Old 09-25-2002, 10:31 PM
91F250DSL's Avatar
91F250DSL
91F250DSL is offline
light grey/white smoke when decelerating is usually a sign of cavitation on the cylinder wall... looks like your engine is starting its last leg... thankfully mine does not smoke what so ever that way..
if I get 50-100K out of this truck (paid only 1500$) I will more than happy!
>Hey "91F250DSL - Patrick Bureau" you mentioned piston
>compression at every 100k miles. I've got an F250 7.3l
>diesel with 218000 miles and it smokes after 3 hrs driving
>when I let off the accelerator. Smoke is light gray/white.
>Could this indicate rings or valves need replacing?
>Thanks
>DieselSteve
Old 09-26-2002, 09:07 AM
dieselsteve's Avatar
dieselsteve
dieselsteve is offline
I don't get the smoke all the time. Will a compression test reveal cavitation? Are there other things to check so I can confirm or rule out cavitation?
I just bought the truck used, so I'm planning on flushing the coolant, putting in additive; getting the injector pump rebuilt, replace return lines, and get new injectors.
Old 09-26-2002, 09:11 AM
Sam Wactor's Avatar
Sam Wactor
Sam Wactor is offline
I think that I'd service that tranny. New filter and fluid. Drain the converter while you're at it and clean the goop out of the pan.
Old 09-26-2002, 11:12 AM
The Diesel Dude's Avatar
The Diesel Dude
The Diesel Dude is offline
Old 04-21-2003, 06:41 PM
Logical Heritic's Avatar
Logical Heritic
Logical Heritic is offline
dodge claims 95% of pickups sold in the last 20 are still on the road.Mostly gassers though.
Old 04-22-2003, 11:49 AM
RedTaurus94's Avatar
RedTaurus94
RedTaurus94 is offline
I've heard that if you once neglect the tranny fluid service, it's best not to change it. For example, if you go twice the recommended miles or something before thinking of doing the service, then changing it could cause more problems than just leaving it alone at that point. I'd say the best plan would be to service the thing like the book says, but if those sevice items haven't been done on a regular interval, and the fluid looks good, and the service man says not to change it, then I'd go by that. Just be prepared to "pay" for all those missed fluid changes eventually.........
Old 04-22-2003, 01:40 PM
444stroker's Avatar
444stroker
444stroker is offline
you're better off not changing the fluid/filter, if you do, expect a slipping transmission real soon, the reason behind this is the longer the fluid is in service the more cluctch material and whatnot is in it, the more like a friction material it becomes. when you drain this, there goes your fruction material, and tranny.
Old 04-22-2003, 02:17 PM
AggiePSD's Avatar
AggiePSD
AggiePSD is offline
Service the transmission. Changing the fluid will not cause a transmission to slip, even if it does have clutch material in it. Ask Mark Kovalsky, and I'll put money on it that he says you'd be better off changing it. Pretty much a myth from what I've learned that changing fluid that has been in a transmission a long time will cause it to go out.
Just what I would do
Old 04-22-2003, 04:03 PM
RRMike's Avatar
RRMike
RRMike is offline
I had the dealership do mine when they did the 60,000 mile service and it went out within 10,000 more miles. That was on my 96 though.
Old 04-22-2003, 10:48 PM
AggiePSD's Avatar
AggiePSD
AggiePSD is offline
I think that if the fluid change was the cause of the problem, the transmission would not have lasted even close to 10,000 miles. My truck was bought with 100,000 miles on it, with the only trans fluid change done at 60,000, so I immediately did it when I got it. Drives great so far.
Old 04-29-2003, 11:52 PM
13hondacr250's Avatar
13hondacr250
13hondacr250 is offline
Ahh the beauty of a manual.
Tyler
94 F-250 5 speed 230,000+ No tranny problems.
Old 05-01-2003, 12:43 AM
oldarcher's Avatar
oldarcher
oldarcher is offline
Thumbs up 7.3 Diesel Longevity?
I have an 1989 7.3 in my F350 and it has just turned 400,000 miles. Only draw back is the injector pumps ... they seem to last about 105,000 miles before replacement. Same vehicle different part I have never replaced the front end it's still factory original even though I plow with it.
  #28
Old 05-04-2003, 07:11 PM
tdmontg's Avatar
tdmontg
tdmontg is offline
I'm the fleet manager with a national ambulance company. For budgetary reasons, we keep our ambulances for up to eight years and many have over 300,000 miles when we get rid of them, running I might add. The 7.3L diesel is the best motor on the road for van and truck applications. Many people say " 300,000 isn't impressive", but when you consider the conditions by which these vans are driven, it is.
These vans are driven by different EMT's daily. Some have good driving habits, some have very bad. Regardless of driving habits, the fact still remains that these ambulances sit idleing for anywhere form 80 to 120 hours per week. When they run calls, it is usually full throttle, hard brake. Now, that is impressive when you compare it to normal everyday driving. We figure that an ambulance with 300,000 miles is equivelent to one driven under normal conditions at 500,000.
In my 7 years as the fleet manager, I have only replced " 1" motor. It only had 255k, but was run without oil.
  #29
Old 05-05-2003, 09:09 PM
13hondacr250
Hey tdmontd,
What do you guys run for oil? And how often are your changing?
Tyler
95 F-150 302 5 speed
94 F-250 PSD 5 speed
  #30
Old 05-14-2003, 12:04 PM
RockyT's Avatar
RockyT
RockyT is offline
Glad to hear about the long life of the 7.3l, as I jsut bougt my F350, Supercab, Dually. It has the Banks Turbo and Banks Engin brake installed, that baby really has some torque. Really nice to know it's going to be around for a long time
Quick Reply: 7.3 Diesel Longevity?
